Q7 MK 1 Discussion Discussion forum for the Audi Q7 SUV built from 2005 to 2015
Spark plug and ignition coil replacement isuses in the 3.0T
Old Feb 17, 2025 | 10:12 AM
JYD's Avatar
JYD
Default Spark plug and ignition coil replacement isuses in the 3.0T
So.. there is a longer story to how I got to this point, but suffice to say that it is currently not important. I am trying to replace the spark plugs and the issue I am currently facings is that while I did manage to get the ignition coils off of the 4,5, and 6 plugs, the damn rubber boots inside the coils ripped off and are stuck on the plugs down inside the engine. I assume that when I do the other side, I will probably have the same issue, so yipee... wasn't planning on buying new coils but that appears to be unavoidable. The more pressing issue is getting the rubber boots off of the plugs so that I can remove them. So, hive mind, what have you got for me? FWIW, I am not certain when the last time was that the plugs were changed. I have owned the car from 153k miles to now, which is about 225k miles. I have a friend that mentioned that there is a tool to get the boot off, but from what I am seeing, I am not sure that I am finding the right thing, and I don't want to eff this up.
On a related note, suggestions for new ignition coils? Do I really need to pay for the Audi branded ones, or can I get the NGK, Danso, or Hitachi ones?
Old Feb 17, 2025 | 11:19 AM
jbgilbank's Avatar
Been there recently! No Problem, but you will need a 6 - 8" pick/hook or dental hook. You can grab them out, but it could and did me, take several tries.
Once you get them out, get yourself some dielectric grease for the boots and never sieze for the plug threads
How did you get there, curious? Misfire? Like me?
Old Feb 17, 2025 | 12:23 PM
'10Q7TDI_Prestige''s Avatar
Community Influencer
Active Streak: 30 Days
You can overpay for the OE Audi part, or just buy the OEM part directly, which is the exact same part as the OE, but simply at a lower price point. Since the service interval for the plugs/ignition coils is well surpassed by the miles you've driven it, it's definitely time to replace all of those key ignition parts. Go look up the service intervals and print those out.
One key service interval on the 3.0T engine is changing the oil like your motor's life depends on it...about every 6500 miles, or less, depending on how you drive it.
Old Feb 18, 2025 | 11:32 AM
-Wes-'s Avatar
I am not sure if this would be the right shape to reach in there, but I bought a set of these a couple years ago, and I am continually finding a use for them!
Old Feb 18, 2025 | 10:47 PM
JYD's Avatar
JYD
It all started with a P0068 error code about 2 weeks a ago. Then it went away, so... strange but not unheard of. I am pretty sure that I got some bad gas once which caused that error once before. Then the error came back last weekend, so ok.. need to get that looked at, and need to change the air filter (which I knew I needed to do anyhow). Stop downtown to help my wife with something and when I started the car, the engine starts running like crap, pull the codes and voila, P3003 mis-fire city. Changed the air filter, and tried to clean the MAF... spoiler alert, the car doesn't have one....so, spark plugs and coils it is. And, in hind sight, I am wondering if part of the cause of the boots ripping is because I was doing this outside... in about 12 degree (F) weather...
Old Feb 18, 2025 | 11:04 PM
JYD's Avatar
JYD
ok.. but which OEM part. I have seen multiple ones. Which brand do you prefer? I have seen Bosch, NGK, Carquest, Delphi, and Denso. I know that Hitachi is the OE maker according to the parts guy at the Audi shop I called.
The changing the oil thing is kind of funny to me. To quote the lyrics of a song... "I drive it like I stole it".... I do get the oil changed, but at the same time, I have a leak on the rear main seal, which, according to my mechanic is a $4000 leak. The car has 230k miles on it now, and I'm not sure that I want to spend that kind of cash on a 11 year old car, so I keep a 5 qt jug in the car at all times. As it is, Audi says that it is normal to use a quart roughly every 1k miles, and I get between 750 and 800, so, I cycle oil.
Old Feb 19, 2025 | 10:04 AM
TodeVAG's Avatar
Definitely been there...https://www.audiworld.com/forums/q7-...ction-3010356/
Old Feb 26, 2025 | 01:42 PM
JYD's Avatar
JYD
So..... my mechanic lives across the street, and yesterday, he fixed the car. Told me that the other 3 coils, the rubber boots ripped as well, and, not only that, I had 2 different brands of spark plugs in the car, with one brand labeled VW AG, so he thinks that it is possible that the plugs, or at least those 3 plugs, were never replaced. Car runs better than it ever has in terms of responsiveness, and initial indications are that I am getting better fuel economy. Now, the strange thing is that after driving the car roughly 60ish miles or so, after getting the car washed and filling up the tank, check engine light came on, and I am getting the P0068 error again, with a flashing Evap indicator. Where should I be looking next, and I suppose more importantly, is this going to be an issue with driving the car in the short term while I figure it out? I have a 500 mile driving day tomorrow for work up in the mountains, and I am not keen to have issues.
 Pouria Savadkouei
 Michael S. Palmer
Old Feb 26, 2025 | 02:57 PM
You've got to scan the car to see what it'll tell you about the fault issue. That's always the first thing you do. Thank goodness your mechanic lives across the street.
That you are listing a generic P-code means your scan tool is 'meh', and not really supportive of a level of diagnostics on this car that will help you resolve minor issues quickly.
Old Feb 28, 2025 | 08:32 AM
JYD's Avatar
JYD
oh.. it is totally a meh tool. I actually bought it for a different car that I had which used to throw a weird random error. Don't have that vehicle, but I still have the tool. That being said, I did drive the car up into the mountains and back, roughly 400 miles round trip, with no issues except that stupid check engine light. I got 1 cloud of white smoke on initial start up yesterday. after than. nothing. Car ran great, and way better MPG than I have been getting. Mechanic thinks that I need to replace the PCV/oil separator, but none of my research on that code indicate that as an issue. They all point to MAP and throttle position. I did see one post where someone suggested cleaning the throttle.
Thoughts?
