H9 Everstart Platinum BEM code
Yes, most of that same AGM H9 battery line are manufactured locally by the Johnson Controls Battery (JCB code) factory. There's only a few car battery manufacturers worldwide, and so that's why they tend to all look exactly the same and have exact same specs on them...only the top 'store brand' sticker is different.
Often times, you will find a battery in an auto parts store will have the BEM code sticker (the flooded battery or AGM versions) and they will have a sticker saying made in Germany and having the Varta code. I've peeled up a few in the auto parts stores around me to see what they are actually selling. and was surprised by what I found. When I looked at the shipping label on the battery I received via FEDEX, I then looked up the location it came from, which turned out to be a huge battery factory in USA, which JCB Group had bought/ taken over a couple years ago...kinda interesting when you realize what items are a lot more generic than you might think...like major appliances, for example. Only a few factories worldwide actually produce all those brand names of major appliances. It's exactly the same with automotive batteries...put some lipstick on that pig (diff brand sticker/badging) and wholesale the same product to all retailers...now that's marketing.
I ended up using the AGM part # (first series of BEM code), then the Varta code, and just made up a reference date code to match the install date in car for easy reference for the final dataset entry. The main item is the part#, which tells the BEM how to maintain/charge that type/size of battery correctly. AGM part # differs slightly from the flooded part #, etc.
Basically I eventually went from
THIS
000915105DL VAO 370810A14Y
TO THIS
000915105CF VAO 370811A14Y
(This was accepted, but I don't know if anything was benefited as a result, the battery warning went away)
If someone can help me change the second string to correspond to a recent date (battery manufactured JUN2024, I installed it today FEB2025) I would appreciate it. I don't know if the computer bases things off of date of manufacturing or installation and there is too much going on with the original BEM to figure out how it corresponds to a manufacturing year of 2018 🙃.
My new way was easy to interpret "06/24 BEM: 7P09151050 JCB240614E0PB"
