Q7 MK 1 Discussion Discussion forum for the Audi Q7 SUV built from 2005 to 2015
Suspension issue
Old Feb 22, 2025 | 02:27 PM
Bason2000's Avatar
Default Suspension issue
What would cause a Audi Q7 suspension to be higher on the left side and lower on the right
Old Feb 22, 2025 | 04:30 PM
'10Q7TDI_Prestige''s Avatar
Community Influencer
Active Streak: 30 Days
Air suspension not being calibrated, or an air leak on one side, etc.
On steel susp, if a strut gets replaced with a 'quick strut' that includes a new spring, often it will sit higher due to the new spring, etc. There could be other possibilities also, but as you give nothing in details about your car, that's all my time you get.
Old Feb 23, 2025 | 05:08 AM
Bason2000's Avatar
2007 Audi Q7 have calibrated but the suspension is always 2 cm higher on the left than it is on the right also have done a recent error scan and two errors show up. One is for compressor overheating due to cut off and the other one is pressure over duty deactivation due to exceeded limit
Old Feb 23, 2025 | 03:44 PM
-Wes-'s Avatar
It is very likely that you have an air leak in the system IIRC, we have a few threads here that talk about details and troubleshooting.
Old Feb 23, 2025 | 04:13 PM
Follow the error codes: Compressor overheats from having to run too often (air leak in system), or simply because it is very old and not pumping efficiently any longer. Old compressors are usually 100% saturated with water in their dessicant canister, which obstructs airflow, and they are just worn out and corroded internally due to the excessive moisture build up. For reference, our compressor died at 105k miles on the car. Swapping it out for new Webasto compressor resolved pump problem. Go read some dedicated threads on topic, as you'll be very tempted to try cheap re-build remedies and/or cheap, knockoff parts, etc.
The fact that you say you did the level calibration, which is the procedure that levels the car out evenly if you measured and saved the values correctly (it took 3 attempts to be able to save the new measurements on our Q7 w/air susp, btw). It's still unclear whether you are saying the car is dropping in height at all when it sits for any period of time, or if it maintains height perfectly overnight, but the left side is just slighly higher than the right side at all times...the car is not dropping at any corner based on actual measurements taken/verified.
Old Feb 27, 2025 | 11:36 PM
Q7Kopfschmerzen's Avatar
This is a common symptom of a blocked residual pressure valve. Each air spring has a valve which is designed to snap shut in the event of a sudden pressure drop downstream of the air spring.
If you have VCDS, you can test them. Set the suspension to lift. Go the the output tests on the suspension page and instruct the suspension to lower one corner at a time. The correctly functioning corners will exhibit a solenoid click and hissing of air being released. On the corner with the blocked valve, you’ll hear the click but no hissing. The absence of a click would indicate a faulty solenoid.
Old Feb 28, 2025 | 04:54 PM
Kudos on posting!
This is a great bit of detail for the testing/diagnostic purposes, but it mostly ignores the existing/recurrent fault codes his car has, and that to successfully store the new height measured at each wheel, which is required so that the car can make it's final leveling adjustments, you have to take the measurements on a level surface and there can be no fault codes present in the air susp system. Even then the procedure to enter the new values may still error-out/fail to store the new values, etc. For this reason, the final step in the leveling procedure is to immediately look for fault codes in that control module and reverify it saved the new height measurements...or not. If it did save them, then the car also goes through an automated 're-leveling' based on the new measurements entered, etc.
Old Feb 28, 2025 | 05:08 PM
Edzzed's Avatar
Heavy passenger
 Pouria Savadkouei
 Michael S. Palmer
Old Feb 28, 2025 | 05:13 PM
Kudos on posting!
That’s a nonsense train of thought.
Regardless of stored faults, incorrect calibration, etc, the system is ridiculously easy to check for basic function using VCDS.
Those residual pressure valves are not a typical fitment on what is otherwise a pretty common air suspension system, and they clearly have a finite life.
No point wasting time trying to pin down the reason for an overheated pump, etc when you can quickly just check that the car will actually raise and lower at each corner. Chances are it won’t.
A basic function check before chasing faults is the logical way to proceed. If it won’t raise and lower on each corner, calibration or diagnosis might be possible but will probably be futile.
Luxus Panzer
Oct 5, 2021 07:02 PM
Always Overcharged
Nov 18, 2005 09:11 PM
gliTTch
Apr 27, 2004 01:35 AM
S4iscool
Sep 18, 2003 02:30 PM
1100hpTT
Jun 11, 2002 02:55 PM
