Q7 MK 1 Discussion Discussion forum for the Audi Q7 SUV built from 2005 to 2015
Bumper light out
Old Mar 16, 2025 | 07:48 AM
kebabtomte's Avatar
Default Bumper light out
Hi,
I just bought an Audi Q7 from 2010 and have got the following error code with vcds02960 - Lamp in Bumper; Rear Left & 02961 - Lamp in Bumper; Rear Right
I made some measurement and there isnīt any voltage to the bulbs either when they are out.
This problems seems to come and go. Is there anyone who has any idea where to start looking for the problem?
the problem apliece to all of the bumper lights, fog light, turn signal and revers light.
Old Mar 16, 2025 | 11:52 AM
'10Q7TDI_Prestige''s Avatar
Community Influencer
Active Streak: 30 Days
This car monitors lots of things, but especially specific light bulbs that'll throw a message up in the driver's info display, etc. It shuts down power to the circuit when it senses a diff voltage draw in that circuit from what is 'normal' with the OE/OEM, etc., type bulbs from factory.
Those rear lamp strips are pretty easy to remove if you look it up...basically just remove the blocker plug, need decent length screwdriver to reach the retaining screw, and voila'...it cantilevers out of the opening, so you can service the bulbs/inspect the wiring and sockets, etc.
I've got a '10 also, and have had to replace a bulb back there. If you tried to install generic/aftermarket LED bulbs as reverse bulbs that'll kick out a fault code too, as this is a very, very sensitive CANBUS system. There's only one overpriced LED bulb that definitely works as a reverse lamp on this car.
Old Mar 16, 2025 | 12:28 PM
kebabtomte's Avatar
I had the lamp socket out today for inspection all the bulbs are fine and the wiring looks visually fine. Since they are working first minutes after starting the car. I could also see that the entire socket has been replaced due to a date stamp.
So am I understanding correctly that the car can shut off the power to the light bulbs if it feels like there is some bad ground connection or some loose connection or similar?
Old Mar 16, 2025 | 08:09 PM
Yes, but it's just looking at circuit continuity (not being grounded) and the voltage level passing through the circuit, which is a known value/range; this is why using correct bulbs in these fixtures is extremely important.
Are you saying the individual light socket (one bulb holder) was replaced, or the entire lighting assembly for one or both sides has been replaced, which is indicative of a prior rear-end collision or a driver's parking lot back-up boo-boo, or ice dancing tryout perhaps. Check the part # to verify those are the OE parts...take pics to save time, and double verify there are no aftermarket LED bulbs installed as reverse lamps or in any other bulb locations on those bumper fixtures, as those would likely be the reason...wrong voltage pass-through results, and car thinks there's a problem. Based on those two codes you provided, it should be relatively simple cause/effect scenario. The fixtures being replaced adds complexity if they aren't the OE light fixtures (Magnetti Marrelli part, etc., so check all the details.
jamal321
A4 (B9 Platform) Discussion
Jan 4, 2022 05:02 AM
Kc Taylor
Q7 MK 1 Discussion
Mar 18, 2012 04:49 PM
sharding
Jul 29, 2011 05:24 PM
tgt
Q5/SQ5 MKI (8R) Discussion
Jan 13, 2011 03:33 PM
Neutronian
Aug 23, 2005 05:11 AM
