Headlights cut-out when not in auto-mode
- 2015 Audi Q7 TDI Prestige S-line
- LED bulbs installed in main projectors and in fog lamps
- No VCDS customizations implemented for headlamps.
I discovered this problem when driving one foggy/rainy evening where I switched over to manual-on and pulled the **** out so I could also use my fog lights. After a few mins my headlights shut-off and so I turned the **** to off and back on to auto and they turned back on. I assumed that perhaps my fog lights were the problem, and tested the system again later by manually turning-on the headlamps without fog lights and they also turned-off after a few minutes.
I scanned my vehicle with VCDS and don't see any stored error codes associated with the external lighting. Any suggestions?
IMHO, if it were the housings/ballasts/bulbs, or a relay or wiring problem, then the switch position shouldn't matter. I can't think of anything else offhand, but if there are ANY fault codes showing up not related to door handles (LOL! Yes, a Q7 electrical joke), then post them up for review. It's never good on this car to ignore or discount the existence of random seeming fault codes, and especially ones date-coded to precede or coincide with when you began noticing the headlight issue.
That said, not everything throws a fault code; if the control switch itself cuts the power due to an internal fault in switch, then you wouldn't expect to see a fault code...it's the source. I'd be curious to know if the DRLs or front/rear markers/running lights also go out when the headlight bulbs turn off. They wouldn't have to necessarily due to the switch design, but it's just a data point to consider if they do go off, etc.
