Rebuilt VR6 issues
The engine was torn down cleaned and measured for trueness on rods crank and cam
long story short i am having an issue with very low power. misfire on 1and 4 specifically and the P0366 and P0016.
I HAVE checked the wiring physically and with a meter to see that the cam sensors are good and receiving signal,
checked oil pressure is correct, voltage is correct.
Throttle body alignment with VCDS
I cannot exceed 65mph on flat ground and that is in 5th gear at 3k rpm with misfires....
I'm supposed to drive this car and my family to Ky from Co in about 3 days' time and need this vehicle running
Please help with any ideas.
Tomorrow I'm going to check the Crank sensor if i can find it and the VVT solenoids to see if signal is getting to them also.
Last resort is pulling the engine yet again (this will be 4X) and disassemble the Cam followers to see if they have debris from the melt down.
Wednesday,02,April,2025,20:02:26:59918
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 25.3.0.4 (x64) HEX-NET2 CB: 0.4660.5
Data version: 20250311 DS365.0
www.Ross-Tech.com
VIN: WA1BY74L57D070122 License Plate:
Mileage: 251280km-156138mi Repair Order: q7
Chassis Type: 4L (4L0)
Scan: 01 02 03 05 07 08 09 0E 0F 15 16 17 19 28 36 37 3C 42 46 47
4F 52 55 56 61 62 65 67 6C 6D 6F 72 76 77
VIN: WA1BY74L57D070122 Mileage: 251280km-156138miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
05-Acc/Start Auth. -- Status: OK 0000
07-Control Head -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
0E-Media Player 1 -- Status: OK 0000
0F-Digital Radio -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
28-HVAC, Rear -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
37-Navigation -- Status: OK 0000
3C-Lane Change -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
61-Battery Regul. -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
65-Tire Pressure -- Status: OK 0000
67-Voice Control -- Status: OK 0000
6C-Back-up Cam. -- Status: OK 0000
6D-Trunk Elect. -- Status: OK 0000
6F-Centr. Conv. II -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine (BHK) Labels: 03H-906-032-BLV.clb
Part No SW: 03H 906 032 BG HW: 03H 906 032 G
Component: Q7 3.6-FSI-LEV2 G 1634
Revision: 5CH05--- Serial number:
Coding: 0001175
Shop #: WSC 31414 067 57207
VCID: 6882D2B13E7D7BAA277-803C
VINID: 9D1052A4711C1475001C004208621E3224
5 Faults Found:
000870 - Camshaft Position Sensor B Bank 1 (G300)
P0366 - 004 - Implausible Signal
Freeze Frame:
Fault Status: 01100100
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 251281 km
Time Indication: 0
Date: 2025.04.02
Time: 19:50:22
Freeze Frame:
RPM: 2440 /min
Load: 16.5 %
Speed: 84.0 km/h
Temperature: 91.0°C
Temperature: 0.0°C
Absolute Pres.: 750.0 mbar
Voltage: 14.097 V
000022 - Bank 1: CMP Sensor (G40) / Engine Speed Sensor (G28)
P0016 - 001 - Incorrect Correlation
Freeze Frame:
Fault Status: 01100001
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 251281 km
Time Indication: 0
Date: 2025.04.02
Time: 19:50:38
Freeze Frame:
RPM: 1237 /min
Load: 81.9 %
Speed: 24.0 km/h
Temperature: 90.0°C
Temperature: 0.0°C
Voltage: 14.224 V
000768 - Random/Multiple Cylinder Misfire Detected
P0300 - 002 -
Freeze Frame:
Fault Status: 01100010
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 251281 km
Time Indication: 0
Date: 2025.04.02
Time: 19:51:05
Freeze Frame:
RPM: 2344 /min
Load: 67.8 %
Speed: 61.0 km/h
Temperature: 89.0°C
Temperature: 0.0°C
Voltage: 14.097 V
000769 - Cylinder 1
P0301 - 002 - Misfire Detected
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 251281 km
Time Indication: 0
Date: 2025.04.02
Time: 19:51:05
Freeze Frame:
RPM: 2344 /min
Load: 67.8 %
Speed: 61.0 km/h
Temperature: 89.0°C
Temperature: 0.0°C
Voltage: 14.097 V
000772 - Cylinder 4
P0304 - 002 - Misfire Detected
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 251281 km
Time Indication: 0
Date: 2025.04.02
Time: 19:51:05
Freeze Frame:
RPM: 2344 /min
Load: 67.8 %
Speed: 61.0 km/h
Temperature: 89.0°C
Temperature: 0.0°C
Voltage: 14.097 V
Readiness: 0110 0101
Address 02: Auto Trans Labels: 09E-927-156.lbl
Part No SW: 4L0 910 156 B HW: 0AT 927 156
Component: AG6 0AT 3,6 FSI USA 0010
Revision: --H03--- Serial number: 4025083
Coding: 0001002
Shop #: WSC 31414 790 00001
VCID: 280292B1FEFDBBAAE77-807C
No fault code found.
Address 03: ABS Brakes Labels:. 4L0-910-517-V1.clb
Part No SW: 4L0 910 517 A HW: 4L0 614 517 A
Component: ESP ALLRAD MK25E1 0130
Revision: 00H22001
Coding: 0033809
Shop #: WSC 07140 004 1048576
4 Faults Found:
01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 191
Mileage: 250918 km
Time Indication: 0
Freeze Frame:
Count: 128
Count: 13061
Count: 297
Count: 40960
00668 - Supply Voltage Terminal 30
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 2
Fault Frequency: 1
Reset counter: 192
Mileage: 251191 km
Time Indication: 0
Date: 2025.04.01
Time: 21:03:14
Freeze Frame:
Count: 14720
Count: 4353
Count: 128
Count: 36096
01314 - Engine Control Module
013 - Check DTC Memory - Intermittent
Freeze Frame:
Fault Status: 00101101
Fault Priority: 2
Fault Frequency: 1
Reset counter: 194
Mileage: 251271 km
Time Indication: 0
Date: 2025.04.02
Time: 15:25:29
Freeze Frame:
Count: 128
Count: 13057
Count: 8196
Count: 42240
00285 - ABS Wheel Speed Sensor; Front Right (G45)
008 - Implausible Signal
Freeze Frame:
Fault Status: 01101000
Fault Priority: 2
Fault Frequency: 18
Reset counter: 154
Mileage: 250847 km
Time Indication: 0
Date: 2025.03.20
Time: 11:01:23
Freeze Frame:
Count: 7168
Count: 8193
Count: 54
Count: 50944
Address 05: Acc/Start Auth. Labels:. 4F0-910-852.clb
Part No SW: 4F0 910 852 HW: 4F0 905 852 B
Component: FBSAUDIC6 ELV H31 0220
Revision: 31050601 Serial number: 10601100613353
Coding: 0000135
Shop #: WSC 56746 002 1048576
VCID: 6398C59DC75B18F2F25-8036
Subsystem 1 - Part No: 4F0 910 131 L
Component: FBSAUDIC6 EZS H45 0080
Subsystem 2 - Part No: 4F0 910 335
Component: FBSAUDIC6 KSG H27 0080
Subsystem 3 - Part No: 4F0 910 220 G
Component: FBSAUDIC6 IDG H01 0053
Address 07: Control Head Labels: 4L0-910-7xx-07-H.clb
Part No SW: 4L0 910 732 R HW: 4E0 035 729 A
Component: Interfacebox H43 4610
Revision: 00000000 Serial number: 354KR067515116
Coding: 0002003
VCID: 382242F12E5D2B2A777-806C
Subsystem 1 - Part No: 4F0 910 609 E
Component: Bedienteil MMIC6H01 0060
Subsystem 2 - Serial number: 00000001418939
Subsystem 3 - Serial number: 0114.10.090000000100010899ÿ
Subsystem 4 - Serial number: 010899ÿ
Address 08: Auto HVAC Labels: 4L0-910-043.clb
Part No SW: 4L0 910 043 HW: 4L0 820 043 F
Component: KLIMABETAETIGUNGH05 0060
Revision: 00---012 Serial number: 00000000087842
Coding: 0786470
VCID: 6194CF95DD470AE2E09-8034
Address 09: Cent. Elect. Labels: 4F0-910-279.lbl
Part No SW: 4F0 910 279 K HW: 4F0 907 279
Component: ILM Fahrer H17 0240
Revision: 00000000 Serial number: 4F0907279
Coding: 0014123
VCID: 31347FD5CD27FA62309-8064
Subsystem 1 - Part No: 4L1 910 113 Labels: 1KX-955-119.CLB
Component: Wischer AU716 H12 0080
Coding: 00064792
Shop #: WSC 31414
Subsystem 2 - Part No: 4E0 910 557 A Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH13 0090
Coding: 00150059
Shop #: WSC 31414
Address 0E: Media Player 1 Labels: 4E0-910-111.lbl
Part No SW: 4L0 910 110 B HW: 4L0 035 110
Component: MP3-Changer H43 0390
Revision: 00043000 Serial number: AUZ5ZBF1021845
Shop #: WSC 00000 000 00000
VCID: 1E6EB469ACB9751A9DB-804A
Address 0F: Digital Radio Labels: 4E0-910-593-SIR.lbl
Part No SW: 4E0 910 593 H HW: 4E0 035 593 D
Component: SDAR SIRIUS H06 0080
Revision: 00000000 Serial number: AUZ4Z7F0028178
VCID: 2C0A6EA1EA05978A03F-8078
2 Faults Found:
16367 - Control Module - Error in Flash-ROM
014 - Defective - Intermittent
Freeze Frame:
Fault Status: 00101110
Fault Priority: 5
Fault Frequency: 1
Reset counter: 40
Mileage: 141945 km
Time Indication: 0
Date: 2016.06.14
Time: 06:14:14
16347 - Control Module - EEPROM Error
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 95
Mileage: 245631 km
Time Indication: 0
Date: 2024.06.12
Time: 22:27:14
Address 15: Airbags Labels: 4L0-910-655.clb
Part No SW: 4L0 910 655 A HW: 4L0 959 655 B
Component: 73 AIRBAG AUDI8RH39 0210
Revision: 03H39000 Serial number: 0038QD045G5.
Coding: 0014131
VCID: 2B086DBDEF0B90B20A5-807E
Subsystem 1 - Part No: 4L0 910 339
Component: BF-Gewichtsens. H02 0020
Subsystem 2 - Serial number: 6332QSME19072479E
Subsystem 3 - Serial number: 6342QSME19133279B
Subsystem 4 - Serial number: 6352QSME1A503923A
Subsystem 5 - Serial number: 6362QSME191B0969O
Subsystem 6 - Serial number: 63734SME1A09414B+
Subsystem 7 - Serial number: 63834SME1A091C4B7
Address 16: Steering wheel Labels: 4F0-910-549.lbl
Part No SW: 4F0 910 549 HW: 4F0 953 549 A
Component: Lenksäulenmodul H08 0230
Revision: 00H08000 Serial number: 90026063310288
Coding: 0002042
VCID: 669EDC8934696DDA15B-8032
Subsystem 1 - Part No: XXXXXXXXXXX
Component: Lenkradmodul H07 0090
Address 17: Instruments Labels: 4L0-920-KOM-V1.clb
Part No SW: 4F0 910 930 C HW: 4L0 920 980 H
Component: KOMBIINSTR. M73 H17 0170
Revision: 00800000 Serial number: 5HH5724D6
Coding: 2641268
Shop #: WSC 00000 067 57207
VCID: 2318859D87DB58F2B25-8076
Address 19: CAN Gateway Labels:. 4L0-910-468.clb
Part No SW: 4L0 910 468 HW: 4L0 907 468 A
Component: J533__Gateway H06 0040
Revision: 00H06000 Serial number: 0800D06B27802C
Coding: F5F7FE77347A02
Shop #: WSC 25105 444 58836
VCID: 6C8AAEA12A85578A43F-8038
Address 28: HVAC, Rear Labels: None
Part No SW: 4L0 910 158 HW: 4L0 919 158 D
Revision: 00---009 Serial number: 00000000086289
Coding: 0000006
Address 36: Seat Mem. Drvr Labels: None
Part No SW: 4F0 910 760 HW: 4L0 959 760
Component: Sitzmemory FS H01 0100
Revision: 00000000 Serial number: 00000000896401
Coding: 0082954
Address 37: Navigation Labels: 4E0-910-88x-37.lbl
Part No SW: 4E0 910 888 D HW: 4E0 919 887 L
Component: MNS US H48 0970
Revision: 00000000 Serial number: 313KU067513387
VCID: 2F3079ADDB13EC9226D-807A
Address 3C: Lane Change Labels: None
Part No SW: 4L0 910 566 B HW: 4L0 907 566 A
Component: J0769_SWA_MasterH10 0100
Revision: 00H10000 Serial number: 6PZ 009 014-00
Coding: 0010001
VCID: 2D0C63A5D11F9E82141-8078
Subsystem 1 - Part No: 4L0 910 568 B
Component: J0770_SWA_Slave_H08 0100
Subsystem 2 - Serial number: 6PZ 009 014-20
Subsystem 3 - Serial number: 3F27.08.0700H0800000010244ÿ
Subsystem 4 - Serial number: 010244ÿ
1 Fault Found:
01517 - Control Module for Trailer/Towing Sensor (J345)
004 - No Signal/Communication
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 146
Mileage: 250664 km
Time Indication: 0
Date: 2025.03.15
Time: 16:02:48
Address 42: Door Elect, Driver Labels: 4L0-910-793-42.lbl
Part No SW: 4L0 910 793 B HW: 4L0 959 793 B
Component: TSG FA H12 0130
Revision: 00-00000
Coding: 0051915
Address 46: Central Conv. Labels:. 4L0-910-289.lbl
Part No SW: 4L0 910 289 D HW: 4L0 907 289 A
Component: Komfortgeraet H05 0020
Revision: 0020 --- Serial number: 01026599830000
Coding: 7370781
Subsystem 1 - Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
1 Fault Found:
01134 - Alarm Horn (H12)
012 - Electrical Fault in Circuit
Freeze Frame:
Fault Status: 01101100
Fault Priority: 3
Fault Frequency: 254
Reset counter: 154
Mileage: 224941 km
Time Indication: 0
Date: 2024.01.15
Time: 07:00:13
Address 47: Sound System Labels: 4L0-910-223-BO.lbl
Part No SW: 4L0 910 223 G HW: 4L0 035 223 D
Component: DSP-High AU716 H03 0150
Revision: PROD_01 Serial number: 00000000004612
Coding: 0000026
Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl
Part No SW: 4F0 910 280 HW: 4F0 907 280 B
Component: ILM Beifahrer H10 0080
Revision: Serial number: 00000000059859
Coding: 0012001
VCID: 5EEEF469EC39351ADDB-800A
Address 52: Door Elect, Pass. Labels: 4L0-910-793-52.lbl
Part No SW: 4L0 910 793 B HW: 4L0 959 792 B
Component: TSG BF H12 0130
Revision: 00-00000
Coding: 0051915
Address 55: Headlight Range Labels: 4F0-910-357.lbl
Part No SW: 4F0 910 357 F HW: 4F0 907 357 F
Component: AFS 1 H01 0020
Revision: 00000001 Serial number:
Coding: 0000021
VCID: 290497B5E5F782A2F89-807C
Subsystem 1 - Part No: 7L6 941 329 A
Component: AFS-Modul links H06 0002
Subsystem 2 - Part No: 7L6 941 329 A
Component: AFS-Modul rechtsH06 0002
Address 56: Radio Labels: 4E0-910-541.lbl
Part No SW: 4E0 910 541 T HW: 4E0 035 541 S
Component: TUNER EU/US/RDW H42 0630
Revision: 00000000 Serial number: 388K%067574524
Coding: 0000002
1 Fault Found:
00856 - Radio Antenna
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 5
Fault Frequency: 14
Reset counter: 153
Mileage: 224224 km
Time Indication: 0
Date: 2024.01.09
Time: 06:59:07
Address 61: Battery Regul. Labels: 4F0-910-181.clb
Part No SW: 4L0 910 181 HW: 4L0 915 181
Component: J0644 BEM H12 0530
Revision: -------- Serial number: 00000000066151
Shop #: WSC 25105 444 84543
VCID: 649AC681C2551FCA0BF-8030
Subsystem 1 - Part No: 4F0 915 105 D
Component: von VA0 2611200035
Coding: 344630393135313035442056413032363131323030303335
3 Faults Found:
02254 - Interface to Generator
Freeze Frame:
Fault Priority: 4
Fault Frequency: 10
Reset counter: 153
Mileage: 251048 km
Time Indication: 0
Date: 2025.04.01
Time: 16:54:41
03041 - Energy Management Active
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 7
Fault Frequency: 10
Reset counter: 255
Mileage: 251048 km
Time Indication: 0
Date: 2025.04.01
Time: 16:54:41
01299 - Diagnostic Interface for Data Bus (J533)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 5
Fault Frequency: 2
Reset counter: 193
Mileage: 251195 km
Time Indication: 0
Date: 2025.04.01
Time: 21:06:04
Address 62: Door, Rear Left Labels: 4L0-910-795.lbl
Part No SW: 4L0 910 795 B HW: 4L0 959 795 B
Component: TSG HL H21 0050
Coding: 0051722
Address 65: Tire Pressure Labels: 4F0-910-273-BA.clb
Part No SW: 4F0 910 273 B HW: 4F0 907 273 A
Component: Reifendruck 3 H05 0100
Revision: 00050100 Serial number: 00000900037665
Coding: 0062424
VCID: 2216809998C151FAB93-8076
Address 67: Voice Control Labels: 4E0-910-75x-67.lbl
Part No SW: 4E0 910 754 Q HW: 4E0 035 753 A
Component: SDS 3501 US H45 0630
Revision: 00000000 Serial number: 00000611200162
Shop #: WSC 12336 024 394758
VCID: 343A76C13235CF4A5BF-8060
Address 6C: Back-up Cam. Labels: 4L0-910-441.clb
Part No SW: 4L0 910 441 A HW: 4L0 907 441 A
Component: J772__Rearview 0050
Revision: --H12--- Serial number: 525PA8-J6Y41N7
Coding: 1001201
VCID: 241A868182D55FCACBF-8070
Address 6D: Trunk Elect. Labels: 4L0-910-945.clb
Part No SW: 4L0 910 945 HW: 4L0 827 851 C
Component: ValeoHeckdeckel H25 0290
Revision: --H25001 Serial number: E5030000B
Shop #: WSC 98765 666 38354
Subsystem 1 - Part No: 4L0 910 946
Subsystem 2 - Serial number: E5030100B
Subsystem 3 - Serial number: RD06.03.08--H25001001A0077ÿ
Subsystem 4 - Serial number: 1A0077ÿ
Address 6F: Centr. Conv. II Labels:. 4L0-910-290.lbl
Part No SW: 4L0 910 290 A HW: 4L0 907 290 A
Component: ILM HINTEN 2 H05 0060
Revision: AAH05061 Serial number: 002238168-----
Coding: 0000009
VCID: 261E9C89F4E9ADDAD5B-8072
Address 72: Door, Rear Right Labels: 4L0-910-795.lbl
Part No SW: 4L0 910 795 B HW: 4L0 959 794 B
Component: TSG HR H21 0050
Coding: 0051722
Address 76: Park Assist Labels: 4Fx-910-283.lbl
Part No SW: 4F0 910 283 F HW: 4F0 919 283 F
Component: Parkhilfe 4-Kan H09 0060
Revision: 00H09000 Serial number: 06230632402607
Coding: 0021246
VCID: 2700918DF3E3B4D2EED-8072
Address 77: Telephone Labels: 4E0-910-336.lbl
Part No SW: 4F0 910 336 D HW: 4E0 862 335
Component: Handyforb2 H16 0700
Revision: 00000000 Serial number: 00000007553125
Coding: 0010900
End----------(Elapsed Time: 02:19, VBatt start/end: 14.1V/13.9V)-----------
That said, it's generally a good idea to look at what engine related fault code popped first, as each one contains time stamp. If the camshaft position sensor is fine, then you would suspect a wiring /connection problem between or at the ECU hookup. If that sensor feed isn't working, it would result in misfires /reduced power output as a minimum, so check that first:
5 Faults Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 251281 km
Time Indication: 0
Date: 2025.04.02
Time: 19:50:22
I've checked voltage all the way to the driver side firewall and its good but using VCDS i am not seeing the cams change value based on engine speed or any other parameter
