Water ingress from unknown source?
Someone please help me figure this out. My gorgeous Audi is molding...
2015 Q7 TDI PP
You need to lookup KNOWN issues for the 4L Audi Q7 series (impacts to all of them).
Front Plenum drains beneath windshield both sides get plugged up. (damage to ECU /other electronics modules...water enters front of passenger area/wet carpets in front.)
Front HVAC condensate drain can get plugged up (water in front of car)
Front sunroof drain tubes can leak in the A-pillar joint...water in front of car, etc. (not as common, but it can happen)
The Frigging REAR SUNROOF DRAINS!!!!
These always leak at some point; two drain hoses, one on rear each side of rear sunroof; the hose shrinks/deforms inside silcone connector piece they used, and allows water to escape/run down the drain pipe till it falls off, where it just happens to drip directly over your BOSE Audio amplifier/controller unit where there is a vent hole in the plastic trip above it (right side, rear). The left drain hose typically is what fills up your tire well area, and will endanger the amp from the B&O sound system if you have that one. Either or both of these can be leaking water, but if you got the Bose system you hope it's the left rear drain connect leaking rather than the one on the right leaking, as that one often gets expensive.
Can you tell me WHERE these drain hoses on the rear sunroof are? I will start there. Do I need to pull the headliner?
Also, I have a giant dehumidifier with pump. I dont need dessicants, I will use my actual dehumidifier.
I'd say if all your carpets in front of car are wet, then you got multiple issues going on, as water from rear sunroof stays very localized to the rear cargo area and tire well only. Since you live in a very rainy area, be sure those plenum drains below windshield are clear...there's a little rubber duck-bill type gate-keeper on those drains to keep bugs out, so leaves/junk gets trapped in there...both sides. Many owners just pull off the duck-bills on the plenum drains, but it's a process to get at them. When I wash my car, always look under car to check those drains when rinse my windshield off to be sure they are flowing well.
I took mine to Audi for sunroof drain cleaning, and they are completelly incapable of doing it. I spent 5 hours there TEACHING them what and where to look and what to do for the love of god
