Where do you buy gas daily?
I buy from my local Irving station, which was certified top tier but no longer is. I suspect it's the same fuel as before, but they don't want to pay for the certification.
Costco fuel used to be TopTier, but is not now in several locations. My wife fuels at Costco.
"Costco is listed as a TOP TIER™ gasoline retailer. Find out more at www.toptiergas.com. Kirkland Signature™ Gasoline contains five times the EPA detergent requirement in both regular unleaded and premium grades, and is formulated to clean your engine and help your vehicle run like new."
To the OP; Yes, absolutely it matters if you buy fuel that doesn't have to meet any minimum quality standards; you're just getting whatever the terminal filled the truck up with, which is the base fuel that all stations use. The real difference is in the additives package and how much gets added, as well as water management and other factors that go into the top-tier fuel certification.
Lower fuel quality means less optimal combustion, so your engine is notably perkier and objectively gets better fuel efficiency running on top-tier fuel, be it gasoline or diesel, etc. The why is in oil contamination from blow-by gases, and the carbon-captured piston rings leading to dynamically increasnig oil consumption issues on the 3.0T engines, etc., etc. The problems begin with the diet you feed your Q7.
I have the Gas Buddy app on my phone and have it set to only show me stations with the top-tier fuel (use station filter in settings), so I don't even have to hunt for them. I also have realized that saving ten cents per gallon isn't actually saving me any money if I'm driving out of my way to reach that fuel station, so I don't wait to refuel if I'm below half tank and catch a deal on top-tier diesel at one of my preferred stations.
The other major factor is the fuel station's traffic, because you want a fuel station to be constantly turning over it's fuel supply rapidly, which means less chance of water contamination or storage tank related quality issues....freshly refined fuel is what you want, where possible.
Run a Q7 with generic fuel and it'll run perfectly fine, but then you fill it up with the top-tier fuel at the same octane level, and you will notice the difference, as will your engine, throttle pedal foot, and your backside G-meter, depending on how you drive it. You still need to be changing the oil at about half what Audi 'recommends' on the 3.0T engine if you want to avoid major issues down the line, and service all the driveline fluids Audi says are sealed/lifetime fluids requiring no maintenance.
Welcome to the world of Audi-isms and planned obsolescence.
