Q7 MK 1 Discussion Discussion forum for the Audi Q7 SUV built from 2005 to 2015
MMI Module malfunction
Old Apr 12, 2025 | 11:20 PM
Gonzorodri's Avatar
Default MMI Module malfunction
Hello everyone,
I'm having a problem with the MMI module in my Q7. It doesn't recognize the SIM card when I insert it, and it takes about 5 minutes for the phone to connect via Bluetooth to the car. I reset the module several times and took the car to the Audi dealership, where they told me the module was faulty and the quote for a new one was €6,000.
I've considered buying a used MMI module and saw that few modules EXACTLY match the code that appears on mine, which shows the following information:
MIB2 Main-Unit
FCC ID: T8GA270
IC: 6434A-A270
4M0 035 035 D 0878
4M0 035 035 A 052
A787
The question I want to ask you is, when looking for another module, does it have to be EXACTLY the same, or is there some variation that is acceptable? And another question: I've heard that Audi, to prevent the sale of stolen car parts, doesn't allow these modules to be reprogrammed for any car other than the original one they were installed in. Does this sound true to you?
Thank you all so much in advance.
This is the module i have on my car
This is the module I have.
Old Apr 13, 2025 | 08:56 PM
'10Q7TDI_Prestige''s Avatar
Community Influencer
Active Streak: 30 Days
Hi!
Your in the wrong forum for your MKII, 4M Q7...this is the MK1, 4L Q7 forum.
In general, I'd take what any Audi dealer (Stealer) tells you with a good bit of skepticism, as they don't normally troubleshoot anything; they just replace parts and control modules, as that is their business model. They've already smoked you for a big labor charge simply to scan your car for trouble codes; hooking up a scan tool. Could it be the control module/MIB2 head unit...possibly, but then why does you phone still connect to it, etc. Have you read the owner's manual? Have you turned off your cell phone's Bluetooth and also power-cycled your phone off/restarted it...it's just a computer, after all.
On SIM cards, I'd defer to the owner's manual on the MMI system to give you the correct parameters, but it also comes down to what exactly are you trying to do with your MMI? Don't buy parts to replace the MMI head unit unless you 100% know that is the issue, and there is no better, cheaper alternative, like simply updating the firmware for the MMI, etc. Do the research, or you'll just be throwing parts at a problem...like the Audi dealer does, but they do it intentionally to make money.
Old Apr 15, 2025 | 03:42 PM
4audis's Avatar
I just went thru this with my 2014 Q7 MMI would turn on then shut off, I bought a used one off ebay Make sure PART # IS THE SAME, installed unit then took to dealer for a re flash on the mmi $200 FOR UNIT $275 FOR REFLASH WORKS LIKE IT SHOULD
Old Apr 17, 2025 | 06:41 PM
There's also a new Apple iPhone update version just dropped, which notes specifically about fixing Bluetooth and Carplay type connectivity issues, so if you have an iPhone, be sure to update to latest revision.
https://forums.macrumors.com/threads...y-fix.2455455/
Old Apr 22, 2025 | 12:12 AM
Gonzorodri's Avatar
Thanks guys for all the posts and help!!! Really appreciated.
schirice
A4 allroad (B9 Platform) Discussion
37
Nov 4, 2025 12:14 PM
KORUN
May 28, 2021 04:31 PM
mcmurray
Audi A3 / S3 / RS 3
Jan 3, 2021 10:02 AM
reardoma
A4 (B8 Platform) Discussion
Oct 25, 2020 08:41 AM
Forestier
VAG-COM Discussion
Mar 23, 2020 09:16 AM
