Q7 MK 1 Discussion Discussion forum for the Audi Q7 SUV built from 2005 to 2015
Auto tailgate slams closed
Old Apr 24, 2025 | 05:45 AM
vlkan.q7's Avatar
Default Auto tailgate slams closed
Since I've bought this vehicle, I've noticed that when closing the tailgate, it closes very gradually and then slams closed. I've actually had people comment on it before, it's so aggressive. Anyone else deal with this? What was your solution? I'm hoping it's as simple as replacing the struts for it...
Old Apr 24, 2025 | 10:13 AM
'10Q7TDI_Prestige''s Avatar
Community Influencer
Active Streak: 30 Days
New gas struts; be sure to get the correct ones...it's a heavy gate.
When you remove the old ones and try to compress them by hand or against the floor they'll still feel like they are good, but nope. Have someone/something to support the gate when you change the lift struts. You've been warned!
Old Apr 25, 2025 | 03:00 AM
Blackfunk's Avatar
Top Answer: 1
And make sure you do them one at a time. Seems simple enough but you'd be surprised.
Old Apr 25, 2025 | 04:22 PM
Edzzed's Avatar
Just replaced mine, It would not go all the way up and I got tired of banging my head. They are a bit different than the factory ones but they def work well. I have zero complaints. link below
https://www.aliexpress.com/item/4000...Cquery_from%3A
Old Apr 28, 2025 | 04:38 AM
tay272's Avatar
What they said, replace the struts. Definitely easier to have someone else to help but I managed to do them myself. Basically had to hold most of the hatch weight up with my head and slide the ends onto the ball mounts. I got aftermarket struts that actually seemed to be a tad longer than the OEM's, so I had to over extend the hatch to initially get them on. Once the first is on, the other side should be a bit easier.
Old May 10, 2025 | 05:00 PM
user 4542397525's Avatar
Banned
Which ones did you end up getting?
Old May 12, 2025 | 02:43 AM
tay272's Avatar
I'd have to look em up again, but any of the generic ones will work. Doesn't have to be OEM if you want to save a little money.
Old May 12, 2025 | 11:35 AM
On the gas lifts, they all pretty much look exactly the same on the outside, but it's the seals & overall construction quality and materials that matter for the longevity.
Here's some reference via FCP Euro site, which are lifetime warranted, including OE and aftermarket options to cover front hood lifts and rear gate lift supports, etc. Pay close attention to the fitment notes when viewing an item:
https://www.fcpeuro.com/Audi-parts/Q...lift%20support
 Pouria Savadkouei
 Michael S. Palmer
SFV A4
A4 (B7 Platform) Discussion
Mar 10, 2007 08:49 AM
jmf32
Texas Discussion
Nov 25, 2002 11:09 AM
Jeremy Clarkson
May 30, 2002 08:06 PM
smallTTs
Jul 17, 2001 08:31 PM
vrsix
Sep 28, 2000 06:10 PM
