Q7 MK 1 Discussion Discussion forum for the Audi Q7 SUV built from 2005 to 2015
mmi black screen
Old Apr 24, 2025 | 07:03 AM
AUDIOBOFFINSLTD's Avatar
Default mmi black screen
Hi all,
Wondering if anyone can shed any light before I dig any further with this fault that has developed.
2008 Q7 3.0 base model which frequently has blank screen and the buttons for radio in centre near gear shifter do not light up.
Vehicle fitted with Mr12volt optical CarPlay system and aftermarket reversing camera, which often still show on display. BUT the factory system is doing zero, no lights and just blank.
Used VCDS to do a full scan which shows no communication with some of the devices. BUT oddly the Optical test show OK against everything component wise for both ELECTRICAL & OPTICAL.
Old Apr 24, 2025 | 10:19 AM
'10Q7TDI_Prestige''s Avatar
Community Influencer
Active Streak: 30 Days
If you lost the switch lights for the MMI controller that tells you everything you need to know. The LEDs are located on the MMI circuit board that sits beneath the controller/console area. A common issue normally associated with water/drink spills onto the MMI controls/console, etc. It's not difficult to DIY swap it, but you need to be 100% sure you get the correct MMI circuit board specific for your MMI version, etc. 2008 is the 2G, IIRC, but look it up if you don't know. Since you got a Carplay adapter on it you should know what it is.
paulpassat
S4 (B8 Platform) Discussion
14
Dec 4, 2024 12:42 PM
JayRiley124
Q7 MKII Discussion
Jul 23, 2024 11:58 AM
DrMitch
Audi A5 / S5 / RS 5
Nov 25, 2021 11:35 PM
cbnmss
Q5/SQ5 MKI (8R) Discussion
Jul 16, 2019 02:16 PM
AndrewT1993
A4 (B9 Platform) Discussion
Oct 21, 2016 11:20 AM
