NO: Battery for Audi Q7. HELP!
The foreman has tried to get power from the trailer through the back of the car without success, they have also tried to get the door open woth different tools, nor has it worked.
Does anyone knows how to get into the car to change the battery or get power in the car so the battery fills up? I`m aware that u can lift the car up to get to the battery on the underside, but wonder if there are any simpler tips out there.
Sorry my english, im from Norway so hope u understand.
Thank u in advance.
EDIT: Just saw you're from Norway. Not sure if you still reside in Norway or not, but theoretically it should be a similar process elsewhere...
If you have towing electrics under the rear bumper, you might be able to tap into a positive feed through there. For a negative feed, any metal ground point should suffice.
I’m not sure which side of the starter motor is energised for starting. Does it have a constant positive feed?
If I were going to inflict damage in order to get a door open, my target would be the bonnet release mechanism via the front grille.
The method in the video has potential, but if you haven’t been under the bonnet before then finding and accessing the red terminal could be tricky, but nothing that a bit of internet research can’t solve.
