A/C won’t turn on
You didn't mention any prior A/C or HVAC issues, so that's where to start...simple. You can also just check other mechanical basics like the condition of your serpentine belt (it's still on there, for example). The A/C also isn't gonna engage if the pressure is too high or too low inside the system, and a bad pressure sensor/ switch can also keep it from functioning by providing false values as feedback, etc.
If that doesn't work or you have been experiencing HVAC or A/C problems, then either go pay a professional mechanic shop, or if you DIY, then hook up a VAGCOM scan tool and do a full scan of the car. It's a lot cheaper to buy the VAGCOM scan tool than pay a shop to scan your car / diagnose it even once, and while on topic, if you want to be able to DIY repairs get a good VAGCOM scan tool that will save you both money and...time, and help you diagnose the car properly. I'd recommend the Ross Tech VCDS hands down for advanced troubleshooting and what you can do with it. It's about $200 USD, but that's a one time cost for full, three VIN# access, and you get their support, access, WIKI, forum discussions free, etc.
You can get your car scanned at most auto parts stores, but if they don't have a VAGCOM capable scan tool (some do...ask), then it would only show problems that illuminate the CEL on dash, as relates to the type of scan tool they hook up can't read all the control modules in a VW Auto Group (VAGCOM) vehicle.
If you don't DIY, I'd still suggest you get a cheap one just so you can read the fault codes on your Q7, as that is important on these older Q7s, since a LOT of issues don't cause the CEL or MIL to illuminate. You could get a basic Carista or OBD-eleven. The basic version of those is around $50 or less, but the device can sell for double or more with 'paywall' access included to provide additional access/functions, etc. Beware the paywall upgrades, especially if you don't DIY...not good tools for diagnostics/repair support, but great for just reading & clearing fault codes. I have one I keep in car just for that purpose now...relegated to code reading duty after I found out it sucks at actual diagnostics, LOL.
While it could be your issue, there are several other easy things to verify first, like are both radiator fans running when the A/C switch is ON, etc. Is there freon in system and at correct pressure for it to work, etc. The system turning off can be result of a bad sensor, but also from lack of freon, etc.
If that sensor itself is bad, there's normally gonna be a fault code showing for it. Scan the car using VAGCOM scan tool to see all the internal fault codes, which don't trigger the CEL/MIL lamp on dash or a driver's message, etc..
Here's a related thread:
https://www.audiworld.com/forums/q7-...witch-2950073/
Last edited by '10Q7TDI_Prestige'; May 17, 2025 at 06:07 PM. Reason: add hyperlink
If it's got freon in it, but is just a bit lower pressure than is required for the compressor to run, then IMO, that would be the only scenario you'd want to just add some refrigerant using a set of A/C manifold gauges to do it correctly, or you can buy a recharger kit w/gauge attached at local parts store, etc., and just wing it/hope for the best. Overcharging the system is much worse than it being a little bit low from aging seals, so be sure you know what you doing.
I bought a set of A/C manifold gauges at Harbor Freight for our Q7s, but you can also get them as a loaner tool from most major Auto parts stores too.
