Q7 MK 1 Discussion Discussion forum for the Audi Q7 SUV built from 2005 to 2015
Rear hatch open warning light
Old May 10, 2025 | 05:00 AM
adrefs's Avatar
Default Rear hatch open warning light
The warning for the rear hatch being open won’t turn off. The hatch is operating fine and is completely closed but the red warning indicator on the screen never goes off. Any suggestions? It’s a 2010 Q7 TDI.
Old May 10, 2025 | 01:04 PM
'10Q7TDI_Prestige''s Avatar
Community Influencer
Active Streak: 30 Days
There's a switch located at the base, where the gate is pulled inwards by the closure mechanism. If the switch has come loose or broken away, or even if the gate is simply not closing all the way due to failed soft closer mechanism...any of those can be the root cause.
Start by open/close the gate manually at rear of car and observe below the strike plate (push it down) for any loose/broken bits plastic. If none, then close the gate and observe to see how it closes and whether the soft-closing mechanism is still functional, etc.
The safety switch itself, IIRC, can be accessed directly by pulling up the cargo cover over spare tire area, and it'll be right there by the latch with wire going to it. Pray it's the switch that's loose or busted rather than the soft-closer mechanism, although that's not terrible to replace either.
Old May 10, 2025 | 02:01 PM
adrefs's Avatar
Default Thanks for the advice
I’ll try the things you suggested to both of my recent posts. Thanks!
Old May 10, 2025 | 09:44 PM
I've seen that warning too...a few times in fact.
Once was after I had pulled off rear bumper valence to install tow receiver and simply forgot to plug in the little sensor connector, so that fixed that issue...an oversight on my part during reassembly.
Second time was stopped at a grocery store, loaded in groceries through rear hatch, pressed close button on gate and then boogied around to get in car as it was raining, started to drive off and the hatch open warning went off. That time I was having issue with the actual latch/locking mechanism inside the liftgate was being 'sticky' and it just needed some lubrication on that latch mechanism (mounted in the lift-gate), and all was well with the world again.
belzebutt
A4 (B8 Platform) Discussion
Apr 24, 2023 09:39 AM
CarDiagAMG
Q7 MKII Discussion
Mar 26, 2022 05:04 AM
RNtoNP
Want To Buy - Archive (NO NEW POSTS HERE)
Apr 4, 2014 08:32 PM
apex02
Nov 19, 2002 10:45 PM
Screamin' Cactus
Feb 16, 2001 06:24 PM
