2014 Q7 3.0 tensioner pulley broke
I purchased a new pulley, but want to know what could the cause be? Bad pulley, bad belt?
you loose power steering and alternator, cause thats what that belt is powering
replace it and be happy it didnt damage anything else. You will need to tow the car.
With all that corrosion on yours in the pic, that should tell you something.
Also, don't take it for granted that the old belt shredded and didn't end up winding at least some of it around the inside of the crankshaft drive pulley, as that is fairly common when the belt comes apart like that. Hopefully it didn't damage anything else.
As DIY repair, it's not difficult to do at all, and you can buy a complete service 'kit' for the S-belt system that has all the wear components, etc. to make it simple. It's going to cost quite a bit more to have any shop do it, and you don't wanna take it to Audi Stealer for this basic service...I won't call it a repair as the belt and entire system are wear parts.
Good luck!!! I just did this service on my own Q7...everything I took off the car was original from the factory @ 130k miles (except the serpentine, which had been replaced at least once prior, perhaps twice), and was worn out.
