Q7 MK 1 Discussion Discussion forum for the Audi Q7 SUV built from 2005 to 2015
Audi Q7 Trunk and Gas Lid
Old Jun 16, 2025 | 05:03 AM
Rivindu's Avatar
Default Audi Q7 Trunk and Gas Lid
On my 2008 Audi q7 3.6L I’m often getting the issue where when I press on the buttons on the driver side door to open the trunk and the gas lid since are electronically operated they do not function however this occurs only sometimes which is weird as sometimes when I lock and unlock the vehicle the issue fixes itself sometimes the issue goes away for a few days and comes back sometimes when I turn off the vehicle and turn it back on it fixes the issue aswell however I’m really confused as to which problem is causing this issue I’ve had this for a while and I’ve noticed that whenever the buttons on the door don’t work neither does the electronical button on the trunk itself and I’ve also noticed that whenever the dome lights in the vehicle are functioning the problem seems fixed but when the dome lights don’t turn on aswell the problem is there so I’m basically at the point of understanding where ever the problem is it’s coming for both the dome lights and the trunk and gas tank lid because whenever I open the door if the dome lights turn on as to which they should then I know that the trunk and gas lid works if the dome lights don’t turn on then the buttons don’t work I’d really appreciate some assistance on this matter thank you
Old Jun 17, 2025 | 01:56 PM
'10Q7TDI_Prestige''s Avatar
Community Influencer
Active Streak: 30 Days
Sounds like an issue you just need to make a list and work your way down it.
In no specific order, I'd suggest you verify the easiest items or low-hanging-fruit first:
If you have access to a VAGCOM type scan tool, do a full diagnostic scan of the car to see what faults are stored/present inside the control modules; this can tell you a lot on an older Q7. More than likely there are some 'intermittent' fault codes stored that relate to this issue.
Car battery condition; this is also an item that shows up frequently in a full scan...low voltage type errors/faults. The Q7 will shut down systems if your battery is not sufficiently charged.
Key fob battery replaced? It's cheap, so if you can't remember last time you changed it, change it. The key fobs also have indicator LEDs on them that will flash differently to indicate communication problems with car, and if it doesn't flash when using remote buttons, well, that is the fob battery or internal fault with remote, etc. (CR2032 coin battery)
Lube the contact switches at doors, moving parts in trunk latch (on the gate itself), and also lube the fuel door release as those do eventually get sticky and fail to release (sometimes), until they finally just stop working.
Since your dome lights being lit or not are your 'key indicator', I'd probably look at the electrical switches and the battery voltage and reserve capacity (amp hours) available first. Lots of odd problems on a Q7 link back to the BEM system knowing your battery is weak. The scan of car will provide you a good baseline for diagnostics/further troubleshooting, and may outright show you the culprit. There will be lots of low voltage related fault codes if the battery is weak, for example.
Good luck!!
Rivindu
Q7 MK 1 Discussion
Mar 23, 2025 03:51 AM
CorradoS4
Sep 11, 2008 06:26 AM
Str4nger
Audi Original "S" Cars
Jan 8, 2007 08:32 PM
Ghostfire
Mar 6, 2006 06:26 PM
rbarna
11
Jan 27, 2003 06:53 PM
