Help pls -- Adaptive Light Failure
Anyone have an idea for what to evaluate or repair on the module to address a short in the swivel sensor? Not even sure when it's located...
Here is the VCDS report:
Address 55: Headlight Range Labels: 4F0-910-357.lbl
Part No SW: 4L0 910 357 B HW: 4L0 907 357 B
Component: AFS 1 H01 0010
Revision: 00000001 Serial number:
Coding: 0000032
Shop #: WSC 31414 790 00001
VCID: 2B04DF472F07B9220A5-807E
Subsystem 1 - Part No: 7L6 941 329 A
Component: AFS-Modul links H07 0004
Subsystem 2 - Part No: 7L6 941 329 A
Component: AFS-Modul rechtsH07 0004
1 Fault Found:
02631 - Voltage Supply for Swivel Module Position Sensor; Left
006 - Short to Plus - MIL ON
Freeze Frame:
Fault Status: 11100110
Fault Priority: 2
Fault Frequency: 2
Reset counter: 85
Mileage: 113523 km
Time Indication: 0
Date: 2025.06.18
Time: 16:27:42
This fault code has a known issue TSB linked to it:
https://static.nhtsa.gov/odi/tsbs/20...66426-2280.pdf
Also, on the exterior of the housing are several metallic modules attached; one is the HID ballast/power controller, and the other is for the adaptive headlamps. They have part #s and descriptions on them, etc.
However, I removed and inspected the headlight module. I also removed the controller and ballast modules to inspect them for damage. The modules, wiring, and connectors all seemed clean, dry, undamaged, and seated correctly. However, I re-seated the controller module connector and the other end of the wiring harness that plugs into the motors in the headlight (connector "A" in the TSB). I also found and re-seated connector "B" but did not see connector "C" -- probably would have found it if I had the TSB. After wrestling the headlight module back into position, I was finished working on it for the evening and intend to clear the DTC and see what happens.
Now that I'm armed with the TSB, I may remove the module and look for connector "C" in the TSB if the DTC returns. Thanks again for all the help!
Passenger side
Driver side
Passenger side
Driver side
My question is, WTH caused it? Is it possible the lens was replaced after an accident? It is bent way to weird for me to believe that as well. I mean, it took grunt to bend it back out and it still is not in the right placement, just relieved pressure on the unit it was against.
Still getting the same errors.
These modules are SO expensive. New ones without modules are ~$700-$1,200 each. 10-115 year old used ones in good condition are about $500jeach. Gonna try the chinese aftermarket LED projector module assemblies which seem to be getting a lot of good reviews and are $900 a pair. Buying from Amazon with 30 day refund/replacement policy and 1 year warranty. Fingers crossed that they are truly good quality and plug-n-play. If not, they're going back. If yes, will keep them for awhile and subsequently sell the fully functional OEM passenger module to recoup some costs. Will report back after I receive, install, and evaluate them.
Good luck!
