PLEASE HELP - Air Bag Light
I pushed the check button to see if I could get anymore info and it showed a few things some of which I already knew, Red coolant(really not sure why on that it’s full currently haven’t had any PCv issues as of yet plan on replacing in a couple weeks.) Red oil (I know I have a leak in the valve cover gasket I’m fixing it in a couple weeks and keeping it toped off for now) Red battery(bad battery?) Then the yellows Lightbulb with red x (unknown) Brake (getting them replaced) Battery(don’t know) Windshield fluid(drinks like a mf needs topped again)
My biggest concern right now is the airbag light if I can’t get it figured out I’m gonna have to take it the dealer.
I have a picture of the wire I couldn’t figure.
How about you go look for that two-wire connector you missed under the console and scan the car via VAGCOM so you can see the actual fault codes list of items. There's the safety switch interlock, and that's my bet since you triggered the airbag lamp, but regardless, find it and plug it in securely locked...always be sure you get the electrical connectors locked on this car or you'll be going back in again later.
The 'self-check' button on dash is just that; a basic self-check for important and convenience sensors operation and stuff that may be helpful to know about...low fluids, brake pads low, etc. You aren't interpreting them correctly though; suggest you read your owner's manual is my suggestion.
