Can I have the trunk / cargo dimensions for the 4L
If it is new and in a box, then there's normally some 'dead space' inside the box just for insulating materials to protect what's inside from moving around, so consider that too. Out of the box it might fit, even if the box dimensions are too large otherwise. If don't have a cargo liner, collapse the box for it and use that underneath as a liner. Those D-rings along the sides of the cargo floor are for securing loads, btw.
Good luck!
And if yours has air suspension that kneels for loading, so much the better!
And if yours has air suspension that kneels for loading, so much the better!Trending Topics
Then again, the Q7 is such a tow beast, if I had my trailer back then, I could have just hauled that down there and cackled maniacally all the way!
Edit: I see now that it was in the middle. Could you grab a side measurement on that vertical? If he's at 26", it might matter.
I measured the vertical drop as that's most important, but the actual opening of the gate measured from center bottom of that trim piece to the bottom door seal is approx 32", so there is a bit of working room there to get it loaded in.
If you don't have the plastic cargo area liner I'd put something back there and probably put some cardboard over the edge/sill of the loading area too during loading to protect the rubber door seals and rear valence.
