2007 Q7 3.6 FSI V6 EVAP code P0441
Here's a link to article on the myriad possibilities, but a purge valve is testable, etc., and of course you can easily look of damaged/cracked evap hoses too. These Q7s often get a vacuum leak right where the brake booster's vac-hose meets the engine vac-hose, so definitely check that fitting is still airtight. That one also impacts your braking system, so if been having any issues with soft/low pedal or loss of brake boost experienced, those are clues. Just from quick fault code search found a good bit of archival threads info around that one too, so shouldn't be too difficult to resolve. Suggest you also use the Ross-Tech fault code finder in their Wiki page, as it gives advice specific to these VAG vehicles and the high percentage resolutions.
Here's the promised link:
https://autoexplain.com/audi-code-p0441/
Just make a list.
