Trailer battery charging
Is there any truth to it?
If limited, what IS the limit (amps)?
If limited, HOW does it limit the flow?
It is a MUST for me to charge the trailer (house) batteries while driving. If need be, i have to modify the factory setup, or ADD a fused circuit (simply speaking, run a phat wire from the car power panel (probably best to use switched power) directly to pin 4.
https://i.pinimg.com/736x/c6/2d/4e/c...51144e4057.jpg
https://www.etrailer.com/static/imag...r%20Coded2.jpg
7-Way Vehicle Power Adapter for Furrion RV Observation Camera
https://www.etrailer.com/tracking.as...ode=20715-2122
a) how the Q7 LIMITS the amps (I am not aware of an 'amp limiting' device)?
b) what this limit is.
To get around the 'charging limitation': where is a convenient (easily accessible, rear of car) high amp circuit to misuse (= to splice into, if rarely used). Think 'subwoofer amp' or 'rear windshield defroster' or 'rear heated seats' or 'rear cigarette lighter'.
