Harmonic balancer/crank pulley replacement.
Be aware you will need the 8 new bolts/hardware as those are torque-to-yield fasteners on the crank pulley. (single use only) I saw FCP Euro has the Corteco ($250), OEM part on a good price and has a Febi branded one for bit less than that too. The bolts are $6.99/per at FCP, and they do sell a 'kit with the Corteco crank pulley/balancer and the bolts packaged together...simple.
ECS Tuning has the required bolts on sale for $6/per currently, but do check at local VW dealers, etc. Maybe ECS Tuning also has the crank pulley/balancer for decent price also, but their online catalog is a mess...probs have to chat with them as lots of their parts show up searching on the VW T-Reg, but not showing up in the Audi Q7 TDI search, which is just a cross-reference/catalogue error on their part.]
Remember you will need 8 bolts and the shim below them is also suggested to be replaced; The bolt part # is N91005902
Here's excerpt from the Audi Q7 repair manual (Gen 2 TDI motor)
OE part take-off from our '15 TDI; replaced with the OEM, Corteco branded part for literally hundreds of $$$ in cost savings vs the OE branded part in an Audi box. Don't forget you will need new bolts for this part when replacing it. If you click into photo or expand page view, then you can really see the details of how corroded it is, as well as read the Corteco box part # sticker.
Other than the attention to detail required during the torque procedure, it's just really basic wrenching to swap this part out, and so easy to save huge $$$ by DIYing this.
