Please help Door handle removal
I'm confused by your description of the problem. If the clip fell off, it should be EASIER to remove the door handle.
The sliding clip that moves up and down (and can be lost if slid too high) enables removal of the other sliding clip which moves fore and aft. When pulling the second clip towards the rear, it releases the lock cylinder.
In my experience, the first clip (up and down) is easy to access but challenging to manipulate. The second clip was very difficult to access with a pick tool that fits into a small hole and can be used to give it a tug rear-ward.
So me thinks your problem is with proper access and removal of the second clip. You're either not finding the proper access to pull it rear-ward, or the clip is stuck.
My more detailed explanation here: https://www.audiworld.com/forums/q7-.../#post25995214
