Q7 MK 1 Discussion Discussion forum for the Audi Q7 SUV built from 2005 to 2015
Change oil change interval to 5,000 miles?
Old Jul 28, 2025 | 09:20 AM
jbgilbank's Avatar
Default Change oil change interval to 5,000 miles?
OK, I know I changed the service intervals at one point to 5K, but now, after noticing it is at 10,000 again in the MMI, I cannot figure out how to do it again.
I did:
17 - module
10 - adaption
43 - max mileage to service (changed from 300 to 150) Figuring that was half.
Still 10K stares at me.
What am I missing.
I even watched several videos, still cannot change.
Thank you in advance.
Old Jul 28, 2025 | 09:40 AM
uberwgn's Avatar
Super Moderator
I have been able to do it on our 2011 and 2015 cars. Are you asking about the oil change interval or the service interval that shows up for 365 days?
Old Jul 28, 2025 | 09:57 AM
-Wes-'s Avatar
Yeah, I could not get my service interval (not OCI) to reset last year, either. Not sure what is up with it.
Old Jul 28, 2025 | 10:16 AM
uberwgn's Avatar
Super Moderator
Here's a video of a guy doing it on a newer car:
I only change the oil drain interval to 5,000 miles or so. I don't fool around with the days to next service, but assume the change required is very similar to modifying the OCI.
The key things I have learned is that I always do a complete SRI reset, then I go in and manually change the interval from 10,000 to 5,000. You can watch it reset in the MMI in real time. I alter the Channel value in Adaptation. It's somewhere around Channel 50 or so.
Old Jul 28, 2025 | 02:10 PM
jbgilbank's Avatar
Well, I want to change oil every 5K, so whatever I need to do that.
Old Jul 28, 2025 | 02:12 PM
jbgilbank's Avatar
Here's a video of a guy doing it on a newer car: https://youtu.be/z5w0wURocsQ?si=K9sC9ZQhFFv1fe1L&t=47
Yeah, that is the one I watched. I did a complete SRI reset also, but cannot for the life of me remember how to set the 5K back, how did you do that?
Old Jul 28, 2025 | 04:50 PM
hserus's Avatar
Club AutoUnion
Community Builder
You don't need to use an OBD for that, there's an option right there in the MMI to reset the oil change interval. Car - Vehicle - Service Intervals.
Old Jul 28, 2025 | 05:00 PM
jbgilbank's Avatar
I know that and use it, but I want to change it from 10k to 5k and you cannot do that in the MMI!
 Pouria Savadkouei
 Michael S. Palmer
Old Jul 28, 2025 | 05:07 PM
hserus's Avatar
Club AutoUnion
Community Builder
Oh yeah thanks. Not sure there's a way to change it AND make it stick but I'd love to be proven wrong.
Old Jul 28, 2025 | 06:00 PM
'10Q7TDI_Prestige''s Avatar
Community Influencer
Active Streak: 30 Days
The MMI interface is a simple toggle/reset for the oil change telling the automated tracker you changed the oil. It resets the mileage & time tracker for the OCI...that's all it does.
To change the programmed interval values (mileage/time) you simply have to go into the control module and change the programmed values, then save the new values...exactly what the video linked above shows how to do in VCDS.
The other option is having an OBD-eleven or similar app-based VAGCOM that supports 'convenience modifications/programming'. My OBD-eleven will change the service intervals for me in exchange for a few points on my OBD-eleven account, and there are a handful of other useful mods or basic functions I have used my OBD-eleven's pre-programmed 'toolkit' to activate as well. I've even used it to run the fuel pump after changing the fuel filter...a one-touch option. It's not great as a diagnostic tool, but it does have its' moments.
Truth is you can do almost anything except security coding using VCDS, so if you are not naturally curious like me, then do your research on how to use VCDS for what you desire to change. So many tutorials out there on how to use VCDS, including directly from Ross-Tech.
