GIAC chip: Pressure tested, changed DV, N75, and plugs and still having boost issues
Had immediate surging issues and was going into "safe" mode where boost is restricted.
Was getting 17964 Charge Pressure Control: Negative Deviation DTC.
Replaced DV, replaced stock N75C with new N75J, replaced OEM plugs with NGK BKR6E gapped to 0.030.
Car drives and boosts a lot better now after starting up fresh but still occasionally goes into safe mode if I am driving her hard on the highway.
Haven't had another chance to check for codes again - any thoughts?
David
Check your L hose.. I hope you already had the factory one replaced! :-o Also check the vac hoses that go from your intake manifold to the N249, and the vac hose that goes from the N249 to the DV. These are common failure points. Especially the L hose on the 2001.
<img src="http://pictureposter.audiworld.com/8422/a4leak1.jpg">
I never checked the DV as i had just replaced it and it turned out that the newly replaced DV was the cause. I didnt have a record either of when i installed it so between 1-3K miles and the thing went south on me.
<a href="https://forums.audiworld.com/a4/msgs/2349177.phtml"> The cause</a><ul><li><a href="https://forums.audiworld.com/a4/msgs/2337436.phtml">the problem 17964</a></li></ul>
if you really want to upgrade your n75, i would recommend the latest stock part, the n75f.
throw back in your n75c or get an n75f.
Pressure is rising above the threshold as the N75J is allowing it to do so, resulting in "overboost". Sorry - still no VAG COM, so no codes. Changing back to the N75C/F will limit the boost pressure and the cars houldn't exceed the MAP limit and go limp.
What is setting this threshold? Can it be raised?
If I upgrade the turbo to K04 at some point, will I have this problem or will the appropriate N75 limit boost (and therefore the effectiveness of the new turbo)?
when you get a k04 you need to get a new ecu tune designed for a k04 from giac.
