Drilling Non-Foulers out for the life of me I can't get the 02 sensor to seat when drilling w/ 1/2"
Old Jun 16, 2006 | 06:19 AM
bassed-ndzmorezone5's Avatar
Default Drilling Non-Foulers out for the life of me I can't get the 02 sensor to seat when drilling w/ 1/2"
Tricks? I've gone through 2 sets of non-foulers trying now and I am about to give up and just run with a perpetual CEL.
Old Jun 16, 2006 | 06:22 AM
Silver Streakin''s Avatar
Member
Default you can't get the sensor onto the non-fouler? please clarify your issue
<center><img src="http://pictureposter.audiworld.com/10901/02_spark_plug_non_foulers.jpg"></center><p>
Old Jun 16, 2006 | 06:26 AM
BSK's Avatar
BSK
Default tbuy a different 1/2 bit the one that you have could have chinese quality to it
and might not be big enough.
clearance will be tight!
Yes I can't drill w/ a 1/2" enough to get the NF to actually have the 02 thread in.
Old Jun 16, 2006 | 06:28 AM
Default I've been looking for a month at all local places for a 19/32 and can't find one either...
I just don't like spending money on 1 time use items, otherwise I would order one online.
Old Jun 16, 2006 | 09:05 AM
Gldnrkt(GT3076R)'s Avatar
Senior Member
Refresh my memory, we need the 18mm non fouler...right???
Old Jun 16, 2006 | 09:09 AM
Default Yep and then short or long depending on what has worked in combination for others...
<ul><li><a href="https://forums.audiworld.com/a4/msgs/2510152.phtml">A few of the results working for others on the board.</a></li></ul>
Old Jun 16, 2006 | 09:12 AM
Member
Default yes
I used 42002 and get a CEL maybe once a month.
<img src="http://www.stephankuehl.com/testpipe/pict00110.jpg"><ul><li><a href="https://forums.audiworld.com/a4/msgs/2511177.phtml">https://forums.audiworld.com/a4/msgs/2511177.phtml</a</li></ul>
 Pouria Savadkouei
 Michael S. Palmer
Old Jun 16, 2006 | 09:57 AM
Chard's Avatar
Default you've got to be kidding.
did you just say that?
Old Jun 16, 2006 | 10:03 AM
RKA's Avatar
RKA
AudiWorld Uber User
Default Buy a unibit...
it's a stepped drill bit, so the width of the hole left is determined by how far you *ahem* penetrated. Don't buy it at your local home depot though...a set of three is $60 there. Get it at a local harbor freight store (Franklin Mills or Norristown). You should be able to get a set of three for about $20 there.
