how to remove stock ic ?
Old Jun 16, 2006 | 01:19 PM
a-4cefed's Avatar
Default how to remove stock ic ?
just want to clean the inside of it took off the bumper but need to know what else needs to come off
Old Jun 16, 2006 | 01:50 PM
pac1085's Avatar
you need to put the lock carrier thing in service position
VTB(Erik)'s Avatar
Default Take the shroud off by pulling forward at the top, then upwards to unhook it from
the two pins at the bottom. The IC in secured by three pins in rubber grommets, two at the top pointing down and on on the bottom pointing backwards. Detach the hoses and pull the bottom of the IC forward to release the lower pin and then push it up to release the two upper pins.
Old Jun 16, 2006 | 01:52 PM
VTB(Erik)'s Avatar
This isn't necessary but you might have to remove the headlight for a little more room.
Old Jun 16, 2006 | 03:06 PM
pac1085's Avatar
i removed my headlight and just couldn't get the damn thing out till i did that (its easy anyways)
Steven L Brown
Q5/SQ5 MKI (8R) Discussion
May 26, 2018 10:42 AM
A4 to A8
Mar 20, 2013 10:41 AM
psuaudi
Oct 16, 2006 03:32 AM
A4xIV / Nadroj
Jul 16, 2004 11:04 AM
Sean Dudding
Audi allroad
Dec 22, 2003 10:26 PM
