Install Head Unit
With the radio pulled out, there are two hex bolts that secure the panel (wood or carbon fiber depending on your trim) to the center console. Remove those and then you carefully pull the whole panel off.
With all that removed, you'll have plenty of access to everything you need. Removing the panel is recommended since it's easy to scratch it while working in there.
