YAY! Got new shoes, Eagle F1 GS-D3 in 225/50-16. Sticky, sticky.
Old Jun 17, 2006 | 07:58 AM
CK:1.8T+Rabbitâ„¢'s Avatar
Default YAY! Got new shoes, Eagle F1 GS-D3 in 225/50-16. Sticky, sticky.
<center><img src="http://www.automobileforum.com/forums/uploads/post-2-1150559863.jpg"></center><p>
Old Jun 17, 2006 | 08:16 AM
paul_858's Avatar
AudiWorld Expert
those are great tires. You'll like them for sure.
Old Jun 17, 2006 | 08:36 AM
gh0st's Avatar
Default TJ: how oversteer prone is your car?
I was all set to pull the trigger on the Vogtland Club Spec springs until a couple days ago. I was at a track event and talking with one of the instructors. He was telling me that just a rear sway will make it oversteer plently and that by putting stiffer rear springs in with a sway will make it tail happy. I like a little bit of understeer. The thing is, he didn't have an A4 so I dont know if there is any truth to what he said, so I figured I would ask you
Old Jun 17, 2006 | 09:17 AM
EDness's Avatar
Default those are great tires...
it made a big difference on my beater car.
Old Jun 17, 2006 | 09:42 AM
Mine too, it's amazing.
Old Jun 17, 2006 | 11:12 AM
j31izzle's Avatar
Default sway bar will definitely help you.
i put hsports on my car but first installed the rear and drove for a day. simple flick of the steering wheel would throw the car around (and set at softer setting). putting the front on neutralized the car a bit but it's a more neutral feeling right now.
i'm thinking of getting coilovers soon (have koni yellows with neu race currently) with significantly higher spring rates in the rear and i'll definitely write a review.
Old Jun 17, 2006 | 02:25 PM
paul_858's Avatar
AudiWorld Expert
Default My car isn't prone to oversteer at all. In fact it's pretty close to neutral.
If you go into a turn hot (0 angle on the road) my car will show a slight bit of understeer until you lift. At which point depending on how fast/angle/load the car will start to oversteer. catching it is easy, just apply throttle. That isn't to say the car won't oversteer under throttle it can. It's very easy to drive.
Old Jun 17, 2006 | 02:31 PM
gh0st's Avatar
thanks, sounds good
 Pouria Savadkouei
 Michael S. Palmer
Old Jun 17, 2006 | 03:51 PM
Shep 1.8T's Avatar
Member
almost impossible to break those loose. I am on my 2nd set
Old Jun 17, 2006 | 08:49 PM
Bobby Kinstle's Avatar
AudiWorld Uber User
25 Year Member
Default I had a set of those
The best handling tire I've ever had. I do suggest you rotate them every other week or you'll be buying a new set in 20,000 miles.
Actually you probably will anyway. Every good year tire I've owned suffered tread seperation long before it was worn out.
Gordo
Jul 24, 2008 09:53 AM
Eric - The Red S4
Jul 30, 2007 06:42 AM
oldseTTer-WWKD
29
Oct 17, 2006 12:57 PM
ITALSKIER
Oct 4, 2006 12:38 PM
