wow my brakes are squealing like nothing else right now
BTDT, you can sand them down and use anti-squeal but in the long run you will be better off swapping pads and saving these for your next track event.
-richard
If that doesn't help, take the pads off and lightly LIGHTLY scuff the pad surface w/ sandpaper. Maybe do the same to the rotor...
basically, you glazed your pads from the heat of track braking... this *should* fix your issue if the pressure washing doesn't.
btw, don't replace the pads... they're fine.
