ABS module removal woes
Old Jun 18, 2006 | 04:09 PM
4corners's Avatar
Default ABS module removal woes
Trying to remove the ABS module on the son's 01 and I've studied the proceedure in the archives and watched the video but one problem remains. Removing the friggn lower connector. Video says push down and out. Enlighten me please. If I can get it off there will be smooth sailing. I also have small hands and there seems to be plenty of room in there without me removing the washer bottle or am I missing something? Thanks for any help with the connector.
Old Jun 18, 2006 | 11:08 PM
undertow999's Avatar
Default Here is a view from inside the wheel well of what you are lookin at..
<a href="http://photobucket.com" target="_blank"><img src="http://i28.photobucket.com/albums/c209/undertow999/ABS013.jpg" border="0" alt="Photobucket - Video and Image Hosting"></a>
The easiest way to disconnect the the connector off is to slide a flat head screw driver and gently bend the connector outwards. Hopefully this pic gives you a little help.
If you need more help, email me again and I can send more pics of when I took mine out.
It would be easier to remove the connector if you took the washer fluid tank out.
Let me know ifyou need anymore help.
pearlwhitesix
Jan 1, 2013 11:12 PM
IBG
Aug 29, 2006 02:37 PM
Mr. Bungle
Jun 21, 2005 11:45 AM
S4 SPDRACR
May 4, 2005 02:38 PM
Kris Hansen
Feb 7, 2005 05:55 AM
