APR STAGE3 CAT PROBLEMS 3RD TIME!!!
Old Jun 19, 2006 | 10:11 AM
porsches4ed (APR S3)'s Avatar
Default APR STAGE3 CAT PROBLEMS 3RD TIME!!!
here we go again, Been getting catalyst system bank 1 eff. below threshold. The other times I kept getting this code my cat was cracked. The last time I had it welded, the guy who did it said it would crack again because the quality of steel is the cheapest kind.
<img src="http://pictureposter.audiworld.com/24446/dsc02471.jpg">
I thought it would hold but it cracked again Am I the only one with this problem?
<img src="http://pictureposter.audiworld.com/24446/dsc02473.jpg">
This was the last one, it completely cracked off. I have the RS4 mounts and they are not blown. My exhaust has a flex pipe at the downpipe. This is getting annoying. There has to be other people with the same problem. I have had stage3 for like 14 months now and this will be the 3rd cat that has cracked, they are all on the turbo flange too. I am thinking they need a V band cat.
Old Jun 19, 2006 | 10:12 AM
AutoXJunkie (Justin)'s Avatar
Senior Member
go for the test pipe...
Old Jun 19, 2006 | 10:15 AM
Audone's Avatar
Junior Member
Default I relocatted my cat under the car and hadnt had any problems..
Are you on the other forum? Might want to check there for advice...
Old Jun 19, 2006 | 10:18 AM
beejohn's Avatar
2nd.. see if you can order a flange and get a 3" pipe welded to it from an exhaust shop
Old Jun 19, 2006 | 10:20 AM
WJM's Avatar
WJM
Tech Guru
same problem exists there
Old Jun 19, 2006 | 10:21 AM
WJM's Avatar
WJM
Tech Guru
Default any advice/pics/how-to's on that?
I would appreciate if you could post something. I am looking to do this soon. You can post it on the other forum if you like.
Old Jun 19, 2006 | 10:34 AM
Default Im gonna get the ATP turbo vband flange
<img src="http://www.atpturbo.com/Merchant2/graphics/00000001/Catalog%20Images/Flanges/Steel/fls023-c.jpg">
I wll have to get the cat pipe with o2 sensors custom made
<img src="http://www.atpturbo.com/Merchant2/graphics/00000001/Catalog%20Images/Flanges/Steel/fls023-d.jpg">
Its $95.00 for the flange
<img src="http://www.atpturbo.com/Merchant2/graphics/00000001/Catalog%20Images/Flanges/Steel/fls023-001.jpg">
Then Ill just get the Vband put on the cat -Random Technology- one that comes with the APR kit. ATP's cat delete pipe is $395 but the orientation of the turbo is different from what they tell me. The manifold they use has the turbo sitting higher on the engine.
Old Jun 19, 2006 | 10:58 AM
WJM's Avatar
WJM
Tech Guru
see the other forum, it was discussed recently, and you can have the cat made up with that
 Pouria Savadkouei
 Michael S. Palmer
Old Jun 19, 2006 | 11:43 AM
DUBITUP's Avatar
Default Just had my Test pipe fail, same problem with the weld breaking. There i sjust not enough
material to weld that flange on so taht it will not fail.
Old Jun 19, 2006 | 11:45 AM
DUBITUP's Avatar
Default Look at my posts in the under Emissions help in the "other" forum
I relocated the cat under the car, no pics but a decent description
