2.8 Valve Cover Gaskets
Old Oct 30, 2006 | 10:07 AM
hanshy5's Avatar
Default 2.8 Valve Cover Gaskets
Do the Valves need to be adjusted or at least checked when the gaskets are replaced?
How much time should I allow? THinking about replacing spark plugs & plug boots too.
Old Oct 30, 2006 | 10:22 AM
Kris Hansen's Avatar
Head Cat Herder
25 Year Member
Default There is nothing you can to to the valves. And, the plug wires are one whole piece...
They are expensive too. If you are not having misfires, don't worry about it till you are.
Old Oct 30, 2006 | 03:52 PM
Shard7's Avatar
Default Depending on your skill level, about 30-90 minutes should do it
I agree with Kris on the wires, I wouldn't replace them unless there's a known issue (check the resistance from coil to plug, should be 6-8k ohms). Best deal I've seen is $100 for the set of 6 (PureMS.com)
Do take photos of the cams while everything is apart, lobe wear is a good indicator of how the engine is aging.
Also, be sure to use a small amount of sealant at the corners of the gasket per the factory manual.
BinsuJiro
Jan 16, 2012 06:40 PM
Toiffel
Jan 3, 2011 04:36 PM
stoc005
Aug 14, 2007 09:13 PM
bluenote
Oct 31, 2003 12:20 PM
Big Ern
Dec 30, 2002 07:00 PM
