Moved to Montana and it's already -1 F, what do I do for cold weather ie. block heater/magnetic pads
Old Oct 30, 2006 | 08:09 PM
OndrejAudiA420's Avatar
Default Moved to Montana and it's already -1 F, what do I do for cold weather ie. block heater/magnetic pads
Ok i think it's foing to be really cold this winter.
I want to make it easier to start the car.
I see there are block heaters available for certain cars, or magnetic heat pads.
What works best?
Is there a block heater for the A4 2.8, and the best place to get one?
Also would it be a good idea to keep the battery warm?
Thanks to all you fellow cold weather folks.
Old Oct 30, 2006 | 08:58 PM
JAFO's Avatar
Default iirc audi/vw stopped offering block heaters quite a few years ago....
one of those oilpan heaters may be your best bet.
Old Oct 30, 2006 | 09:03 PM
ImAwesome's Avatar
Senior Member
Default Well son... in da yukon... we gots a few ways to keep ya car right!
fvck that lingo.. anyways
invest in an oil pan heater. One that mounts directly onto the pan. They are usually held by a bracket and take 120volts. Next up is the batter blanket. Simply wrap it around the battery, run the extension cord to the front of your car. That should be sufficient. Considering you have a manual i'd suggest skipping 2nd... high rev first.. then go third.. to avoid the gear slop... once it warms up shift normally.
Methyl hydrate in the fuel tank will help keep gas lines from gelling... anyways.. that's about it. I've never liked the magnetic pads... we had them on some of our trucks in the past... bad performance. OH one more thing.. there are some heating elements which have glue on them.. you literally stick them on your oil pan. Then you plug them in.. they work great!
run a thinner oil as well.
Old Oct 30, 2006 | 11:37 PM
BJC::wokka wokka's Avatar
Elder Member
Default Rather than skipping 2nd when you shift and rev'in up 1st gear, double clutch and try to keep it
below 4000 RPM till you are warmed up. Stay out of boost if possible.
Old Oct 31, 2006 | 04:15 AM
Mr. Mom's Avatar
AudiWorld Expert
Default I used to have a dipstick heater
plug it in, remove dipstick and insert dipstick heater.
More of a temp use item but it worked great at -20 at the mountain....
You should get a bettery blanket and perhaps an oil pan heater as well...
Old Oct 31, 2006 | 04:37 AM
TighTT's Avatar
I have an extra 2.8 blockheater...brand new. Shoot me an e-mail.
Old Oct 31, 2006 | 05:30 AM
Greyhound Guy's Avatar
Default I have had the heat pad since I bought the car.
It was an Audi accesory. It comes with goop to help adhere and tranfer heat. I liked it better than the dipstick. Your car wont know the difference with that thing on and will start right up.
Old Oct 31, 2006 | 05:38 AM
ScratchRob13's Avatar
yea dont rev up till the oil is warmed
 Pouria Savadkouei
 Michael S. Palmer
Old Oct 31, 2006 | 06:22 AM
northof49(+1+1)'s Avatar
Default block heater, a good battery, synthetic 0-30 and you should be good to go
my 96 has a block heater, you may have to go to an after market parts place to find it. audi stopped installing them up here, i think because of the synthetic oils are good enough without being heated. my2penniesworth
Old Oct 31, 2006 | 07:19 AM
Pelican Pete's Avatar
Default Hey there stranger! You guys got any snow up there yet?
I want to go skiing!
Seriously, long time no see. How have you been? How're the dogs?
Cheers,
Peter
