Any way to remove cam sprocket w/o turning the shaft?
Old Oct 31, 2006 | 08:22 AM
Rosati (Ginzo)'s Avatar
Junior Member
Default Any way to remove cam sprocket w/o turning the shaft?
got her apart again....
fixin the cam seal leak
i dont wanna F* up my timing or go crazy w/ it again , but is there anyway to maybe jam the sprocket to take the bolt out?
no i dont have air tools, that would be the obvious answer i suppose
TIA
Old Oct 31, 2006 | 08:37 AM
Junior Member
nah, impossible, im gonna have to tension the belt again and just hit it w/ the ratchet
Old Oct 31, 2006 | 09:07 AM
77'911's Avatar
Member
Default A comment....
<center><img src="http://samstagsales.com/images/kkt-144.jpg"></center><p>You need a gear holding tool. I've posted a pic of one(made by Kukko). These are quite handy at holding the camshaft sprockets, but removal of the sprocket is a whole other issue.
Old Oct 31, 2006 | 09:17 AM
77'911's Avatar
Member
Default removal...
<center><img src="http://samstagsales.com/images/kk20-20.jpg"></center><p>I use a similar tool in the pic to remove the camshaft sprockets, V6's(5v) use a special factory tool.
Old Oct 31, 2006 | 10:15 AM
Kris Hansen's Avatar
Head Cat Herder
25 Year Member
If you have a V6, just use teh cam bar to lock the cams while you loosen teh bolt...
Old Oct 31, 2006 | 10:25 AM
Audiboy's Avatar
Default Just use markers. When you are ready to tighten the cam sprocket, turn the crank until the marker
on your cam sprocket matches with the mark you made in the cam shaft and maybe one on the bolt and washer.
Old Oct 31, 2006 | 10:38 AM
Junior Member
Default .....please view........
Thanks for the effort. I did what i said and had someone else loosen the sprocket bolt and she ..came right off
i installed the new seal (tapped it in w/ a wood block and hammer)
then cranked it 2x to check the timing.
possible problem:
about halfway into the crank i "hit a wall" and couldnt go any further.
So i backed off and my NEIGHBOR~! cranks it when i wasnt looking and i hear a "CRACK!" but it moves.... and moves freely after that....
maybe it was just at the end of the compression cycle....
so i cranked it after that and it sounded ok (w/ nothing connected)
Im guessing the ratchet made the sound when it skips a cog ....
theres no way anything could have went wrong when cranking by hand right?
Old Oct 31, 2006 | 11:29 AM
Head Cat Herder
25 Year Member
Default If you cranked it one time and it was fine, it would have remained fine.
The 'wall' is compression, it's normal, and good. You probably heard the ratchet, or something else, when the crank went past TDC on whichever pistons were under compression.
 Pouria Savadkouei
 Michael S. Palmer
Old Oct 31, 2006 | 04:56 PM
77'911's Avatar
Member
Default Re: .....please view........
Don't get too worried, just check to make sure everything is on tdc(cam, crank, etc). Crank it over 2 revolutions by hand after you have finished everthing. Its better to make sure then be sorry.
Old Nov 1, 2006 | 04:21 AM
Junior Member
K thanks, i just like to have the AW re assurance
live2tune
Nov 26, 2012 10:41 AM
S4gasm (LoTR)
Oct 1, 2012 10:14 AM
The Red October
Sep 28, 2007 07:45 AM
audix
30v V6 Discussion
12
Jul 28, 2007 10:15 AM
JMP_S4_92
Audi Original "S" Cars
Jul 6, 2006 06:36 PM
