Upgrades and soul searching 2001 A4 1.8T QMS
Old Oct 31, 2006 | 10:41 AM
Monkeyboy's Avatar
Default Upgrades and soul searching 2001 A4 1.8T QMS
Same deal as everyone else...I want more power.
I just got chipped a few weeks ago - loving it!
Let's say I wanted to spend $2k next year on upgrades (outside of normal maintenance, tires, brakes (maybe A8 next year)).
Where can I go?
It is my daily driver, I have the Sport Package and have no real complaints about the handling. I'll likely never track it. Prefer a better, more responsive low end (torque).
The way I see it, K04 is not worth anything on the 2001s. If I go T28 or better, I'm likely looking at $7-$10k in upgrades (for a solid kit) - not going to happen. (say $5k for APR kit, add in install, FMIC, Exhaust, Clutch)
So where do I go from here? I'm thinking I just enjoy what I've got at the moment unless I want to shell out an additional $10k?
any thoughts?
Old Oct 31, 2006 | 10:59 AM
BLKPERL's Avatar
Default $$$
For 2K, you should upgrade suspension, brakes, or exhaust. KO4 will give you 30-40 more hp
For Big turbo:
-Turbo kit 5K
-FMIC 1K
-Clutch $500
Old Oct 31, 2006 | 11:24 AM
bassed-ndzmorezone5's Avatar
Default 7-10K? You can piece a GT2871 kit for less than 3k if you buy it in pieces...
You can go BT for under 4k with a clutch and FMIC if you are not in a rush and do it in small select purchases.
Old Oct 31, 2006 | 03:43 PM
It all depends on how you do it, but either way it isn't cheap.
Old Oct 31, 2006 | 04:26 PM
A4SilverT's Avatar
Default FWIW, upgrading the exhaust will reduce the low end torque slightly
assuming a pipe larger than stock for the upgrade (true of all the usual aftermarket exhausts).
And he said he wanted more low end torque.
Old Oct 31, 2006 | 05:10 PM
BLKPERL's Avatar
You get what you pay for
Old Oct 31, 2006 | 11:02 PM
Merkin's Avatar
AudiWorld Expert
Default bigger the exhaust the better for turbo cars
less back pressure faster spool more torque
Old Nov 1, 2006 | 07:06 AM
Quaboosttro's Avatar
I'm looking at the GIAC FX hammer file w/ the KO4... I hear thats a worthy upgrade.
 Pouria Savadkouei
 Michael S. Palmer
Old Nov 1, 2006 | 07:13 AM
Sal R.'s Avatar
Look into upgrading your TIP as well.
Old Nov 1, 2006 | 07:31 AM
Monkeyboy's Avatar
Default Is this like the AWE kit?
K04, TT injectors, TT MAF, Exhaust, GIAC flash.
FMIC to provide even more power.
If so, this would appear to be a lower cost, (I assume stable) alternative.
