cheapest non-bose speaker adapters?
Old Oct 31, 2006 | 03:27 PM
arizona steve's Avatar
New Member
Default cheapest non-bose speaker adapters?
where is everyone finding their cheapest adapters online? i went in to replace all my non-bose speakers with aftermarket ones and found that the bolt pattern doesnt match up..duh!
the stock speakers have 3 screws in a triangle pattern and the aftermarket ones have 4 in a square pattern.
i havent even looked at the tweeters or rear speakers yet, so i dont know if those need adapters aswell.
thanks in advance..
Old Oct 31, 2006 | 04:06 PM
Chard's Avatar
Default I made a set out of mdf. Seems to be the best way to go
I didn't want to look around online and spend $50 for some plastic part, so I made some from mdf.
It's really easy if you want to do it. Just get the stock speakers, mark the locations of the holes on the board, get your aftermarket speaker, offset it from the stock holes and mark the holes, then cut out a ring. Cheap and easy. It's more solid than those plastic ones too...should absorb the movement much better than a thin plastic ring.
Old Oct 31, 2006 | 05:19 PM
New Member
Default this sounds dumb, but whats mdf?
im pretty sure i see what your talking about though, cant be that complicated.
drill out some stock hole's so it will be held into place, then drill new holes for the new speakers to hold onto...aka an adapter! ha
mdf? whats that, some sort of material thats easy to work with?
Old Oct 31, 2006 | 05:50 PM
BigBobELK's Avatar
Junior Member
Default MDF is a type of board.Multi Density Fiberboard iirc...
What size did you use 3/4" or 1"? Does it clear the door panels? Any trimming of the door panels?
Old Oct 31, 2006 | 09:26 PM
Chard's Avatar
Default I can't remember what size I used
It was a long time ago. I picked it up at the local Home Depot. I didn't have to trim the door at all.
Old Nov 1, 2006 | 04:21 AM
tobin's Avatar
nexxia.co.uk
Old Nov 1, 2006 | 06:26 AM
pac1085's Avatar
Default MDF = Medium Density Fiberboard
Not like it matters though.
4000fixes
9
Nov 14, 2007 03:46 PM
quattro4000cs
May 6, 2005 02:32 PM
dust4
Mar 6, 2003 08:05 AM
Black Sunshine
Jan 9, 2003 06:23 AM
djnelsen
Oct 12, 2001 06:40 PM
