Im going to get hung for this but: Can pulling the e-brake while driving hurt quattro?
TIA
99a41.8tqtip
On dirt or even wet pavement the front wheels have the ability (and probably will) to slide a little as well helping to not "shock" the drivline so much.
Picture it this way: You lock up the back wheels, the front wheels are still turning, the quattro center differential is still trying to maintain a near equal balance F&R... it will be "maxed out" if you will, trying to get the power to the back wheels. Just DON'T GIVE IT GAS while you have the brake on as that will just up the forces multiple times.
Be safe, have fun.
quickly learned that on my car pulling the E brake just got you akwardly sideways in a pointles fasion.
I have matured a tad since then but yeah, if you have DBW you will probably be dissapointed
I actually use my ebrake quite a bit when I drive in the Adirondacks and I'm plowing snow with the A4. It gives me a little more control around turns which I've been used to doing for many years.
I do however have some brass come out of the diff when I drain it, so yes, I am doing a little damage and yes, I know about it.
