Crank pulley looks like it spins uneven?
Old Nov 1, 2006 | 04:53 AM
BoostFrenzy's Avatar
Default Crank pulley looks like it spins uneven?
Am I just seeing things? I only noticed cause my v-belt is wore and when i spray a tiny bit of wd40 on that section of the crank pulley the tiny squeak disappears for a sec so I got to staring at the pulley, looks like it spins out of round but maybe not?
Old Nov 1, 2006 | 05:16 AM
Solaris's Avatar
AudiWorld Uber User
Probably just looks that way. Any vibrations or noise when you rev the engine?
Old Nov 1, 2006 | 05:29 AM
Default yeah i'm currently tracking down some minor hum/vibration that's rpm dependant
but it also looks like my engine/trans mounts are shot and from what i can tell the crank pulley isn't a balancing part anyway so i dunno
Old Nov 1, 2006 | 06:35 AM
WJM's Avatar
WJM
Tech Guru
Default did you do your timing belt recently?
take a peak in with an inspection mirror and make sure all the bolts are still in place. Hate to admit it... but after doing 8 timing belts on 1.8Ts, when I did my Gf's timing belt this past summer, I didnt torque down the bolts well enought and she was getting a weird noise, and noticable amount of activity on the serpentine tensioner about a week later. 2 of the bolts had backed out.
Old Nov 1, 2006 | 06:39 AM
dealer did the tbelt about 50k ago, check the bolts on the crank pulley yer saying?
Old Nov 1, 2006 | 06:42 AM
WJM's Avatar
WJM
Tech Guru
yeah check them out...and like i said, your serpentine tensioner will also show you any wobble
Old Nov 1, 2006 | 06:50 AM
yeah the auto-tensioner up top looks ok, tension changes as revs increase but it looks fine
Old Nov 1, 2006 | 10:35 AM
TomRitt (Homebrewed)'s Avatar
Default Be very very careful! MORE..
Over the summer I noticed this problem and figured id fix it when i got a chance. Well I didnt have to wait that long because the crank gear ended up sheering the key off on the crank shaft which slipped the timing belt, and I had another catastrophic failure.
The bolt holding the crank gear on is a torque to yield bolt meaning it need to be replaced once removed. I would then the dealership would have replaced it if they took it off for something, but I'd make sure the actually crank gear isn't loose before u drive it any more.
 Pouria Savadkouei
 Michael S. Palmer
greenaudiurs4
Audi Original "S" Cars
Feb 18, 2009 05:58 PM
gaber6
Oct 2, 2008 11:27 PM
crew219
Mar 10, 2006 06:38 AM
Kris Hansen
Mar 17, 2003 11:48 AM
