Check Engine Light on After Oil Change
Old Nov 1, 2006 | 05:25 AM
TJR178's Avatar
New Member
Default Check Engine Light on After Oil Change
Hi All,
I just had my oil changed yesterday and within a couple hours, the light came on (and is still on). It was not done at a dealer, but I supplied the factory filter and crush washer. Any ideas?
FYI - I had them put in Pennzoil Platinum (full synthetic) 5W-30.
Old Nov 1, 2006 | 05:40 AM
jguthrie's Avatar
Default That's why you should always change your own oil
It's not rocket science yet so many people come here with problems after letting someone else do it for them.
Pull the codes to find out why the check engine light is on.
Old Nov 1, 2006 | 05:46 AM
xdriver's Avatar
Would pinching the oil sensor bring up a cel or just an oil light?
Old Nov 1, 2006 | 06:09 AM
TJR178's Avatar
New Member
Default If I had time I would.
I know it's not rocket science, I do it all the time with my cars and bikes, but sometimes I don't have the luxury.
So how do I pull the codes?
Old Nov 1, 2006 | 06:10 AM
TJR178's Avatar
New Member
Default Re: Would pinching the oil sensor bring up a cel or just an oil light?
No clue. I'm new to Audi's.
Old Nov 1, 2006 | 06:12 AM
jguthrie's Avatar
Default Mechanic or find someone local with a VAG-COM
I believe the generic code scanners will work but I'm not sure if they support all the modules in the car. Some local parts stores like autozone do this for free. They will most likely only give you a code number, but someone here should be able to look up the description for you.
Old Nov 1, 2006 | 06:36 AM
Shard7's Avatar
There are some oil pressure and temperature related OBD-II codes, so it is possible
Old Nov 1, 2006 | 07:10 AM
Audi Junkie's Avatar
Community Builder
5w-30 in a V6? Good luck with that.
 Pouria Savadkouei
 Michael S. Palmer
Old Nov 1, 2006 | 07:13 AM
TJR178's Avatar
New Member
Care to expand on that?
Old Nov 1, 2006 | 10:57 AM
Silver Streakin''s Avatar
Member
IIRC, when the oil light came on in an A6 2.8 30v loaner car, the manual said to use 5w30 ::shrugs::
