surgin idle.
Old Nov 1, 2006 | 06:07 AM
CURSH's Avatar
Default surgin idle.
Idle drops to 600 or so then the ECU kicks it back up to 1300 or so.
Pissing me off.
I recently replaced to vac lines and flipped over my DV (because I saw an engine diagram and mine was on differently than that one (since I reinstalled it I have been in limp mode so I wouldnt have really been able to tell if it was on wrong)
Anyway, Question 1
Turbo inlet hose goes to the side of the DV (if the top and bottom run on the same axis as the spring)
danke shon.
Old Nov 1, 2006 | 06:16 AM
Casablanca Avant's Avatar
Member
Default Forge DV you want the sealed side going into the Intercooler pipe and the open side going>
into the return to the air box.
Old Nov 1, 2006 | 06:53 AM
CURSH's Avatar
Default the sealed side being the opening with nothing across from it?
thanks
Old Nov 1, 2006 | 07:18 AM
RallyVermont's Avatar
Mr Mc Feely
told you that would happen.. just flip flop the Forge around
Old Nov 1, 2006 | 07:53 AM
CURSH's Avatar
Default wish I had a camera =(
<img src="http://www.mft-berlin.de/pics/forge_dv_r.jpg">
the large opening not sitting on the table is going into my Turbo to intercooler hose.
The end on the table goes back up to recirculate the air.
that is how I have it at the moment
Old Nov 1, 2006 | 08:10 AM
Mr Mc Feely
Default get under the car, head first under bumper.. look up, the top porion on the valve (small vac line)..
should be pointng to your right, you will have to pull around the vac line to fit.
the "offshoot" portion located on the top of the valve slips into the intake line, and the end pointing directly left slips into the intercooler line..
Sorry if this makes no sense..?
Cheers,
Joel
Old Nov 1, 2006 | 08:26 AM
CURSH's Avatar
Default lol, this is nearly impossible
small line attachment - no prob know where it goes.
Long Large Attachment - Goes into the Turbo to IC hose.
Short Large Attachment - goes back to the intake.
The short large attachment is on the same axis as the small line attachment (same axis as the canister)
The Long Large Attachment is on an axis independednt of anything.
thanks.
sorry about the confusion, is that right or wrong?
Old Nov 1, 2006 | 08:37 AM
Mr Mc Feely
Long Large = Intake short large = IC line
 Pouria Savadkouei
 Michael S. Palmer
Old Nov 1, 2006 | 09:06 AM
Member
Default from the picture you included the sealed side it the one inline with the vac line ->
this is the side that needs to point into the intercooler.
stewarbd
Jun 29, 2007 06:04 PM
90Audi200TQ
Jan 9, 2006 10:20 AM
CAJ
Aug 14, 2005 09:29 PM
[Arawan]
Nov 24, 2003 09:06 AM
cpayne
Oct 2, 2000 03:07 PM
