Lighting/Wiring questions??
Old Nov 1, 2006 | 11:18 AM
Ertman's Avatar
Default Lighting/Wiring questions??
Going to tackle retrofitting foglights to my 98.5 this weekend.
Question one - Can the stock foglight housing for 99.5+ handle 100w bulbs?
Question two - I was planning on re-using the rear fog light switch in the dash for the new fogs by moving the rears and old fronts to the same switch. Will there be a problem?
Question three - what size relay should I use for the new fogs, especially if I go to 100w bulbs, and is there a one that i can obtain at a VW dealer?
Question four - where should I mount the new relay? Up in the forward engine compartment or by the kick panel? I don't know if there is an open slot on the relay plate.
Old Nov 1, 2006 | 11:52 AM
WJM's Avatar
WJM
Tech Guru
iwasawesome... let this guy know where you went to have your wiring replaced.
Old Nov 1, 2006 | 11:53 AM
Casablanca Avant's Avatar
Member
Default can't help you with 2-4 but in regards to question 1 the housings should
have no issues with 100 watt bulbs as long as the wiring is sufficient... People have retrofitted HID lights in the fog housings. I would not use the stock wiring to handle a 100 watt bulb though.
Old Nov 1, 2006 | 01:00 PM
JAFO's Avatar
Default here's a tech on the bumper mounted foglight mod.
<ul><li><a href="https://www.audiworld.com/tech/elec90.shtml">https://www.audiworld.com/tech/elec90.shtml</a</li></ul>
Old Nov 1, 2006 | 01:08 PM
JAFO's Avatar
Default this tech will help with the switch mod you want to make....
the easiest way to do this would be to have the rear fog switch run thr rear fogs and the bumper mounted front fogs. while using the front fogs switch to run the in headlight fogs.<ul><li><a href="https://www.audiworld.com/tech/ext10.shtml">https://www.audiworld.com/tech/ext10.shtml</a</li></ul>
Old Nov 1, 2006 | 01:13 PM
WJM's Avatar
WJM
Tech Guru
HIDS are 35watts not 100watts
Old Nov 1, 2006 | 03:22 PM
ModifiedA4's Avatar
Banned
theres an open spot on your relay panel, you'll need to get a socket though.
Old Nov 1, 2006 | 03:28 PM
ImAwesome's Avatar
Senior Member
dealer
 Pouria Savadkouei
 Michael S. Palmer
der_Apotheker
Feb 14, 2007 01:52 AM
Luxus Panzer
Feb 21, 2006 09:44 PM
Max'sCoupeGT
Oct 20, 2003 08:25 PM
S4NoRice
Jan 25, 2002 10:07 AM
ScottAW
Mar 1, 2001 07:51 AM
