i was lovin my H-Sport until my car decided that she hates it, started sobbing and hasnt stopped
Old Nov 1, 2006 | 04:56 PM
B1.8T's Avatar
Default i was lovin my H-Sport until my car decided that she hates it, started sobbing and hasnt stopped
So.. I bought H-sports and the metal links with 10k on them for 250 bucks. That was Sunday and I installed the rear bar that day. I had a great time driving that night with my stock sport front sway. I was really loving it. The next day I started hearing some creaks coming from under the car. Then the same day the car started making popping noises sometimes when the suspension is under tension. Now the car is making all sorts of noises when I go over bumps or take turns slowly. I cant find any pattern as to when it pops or squeeks. The squeeks are almost like a grinding noise. Maybe unlubricated bushings, but I greased the **** out of all the bushings that i could reach-didnt help. The popping noise happens randomly and sometimes a second or two after I finish a turn when there is no tension anymore. It sounds like a plastic bottle popping back into place, but really loud. I think it might be something to do with the subframe.
I spent a good hour under the car today trying to figure out what it could be. The sway bar looks secure and all the bolts seem to be in tight. I really have no idea whats going on. Any ideas are welcome.
Old Nov 1, 2006 | 05:02 PM
quattrokiwi's Avatar
Member
You did get the reinforcement brackets with the sways right?
Old Nov 1, 2006 | 05:11 PM
AutoXJunkie (Justin)'s Avatar
Senior Member
my car creaks coming out of the driveway...but I **know** my poly bushings need lube.so it's normal
Old Nov 1, 2006 | 05:18 PM
qfrog Ti20's Avatar
Default I dont think you can put the rear one in without em.
iirc the brace brackets are what holds the bar
Old Nov 1, 2006 | 05:38 PM
Solaris's Avatar
AudiWorld Uber User
they use the OEM holes, so somebody might get away with that... for a little while
Old Nov 1, 2006 | 05:56 PM
Member
Default Yep you can put them on without, they use the stock mounting holes.
the brakets just go on the other side of the subframe, atleast for the neuspeed i have, iirc
Old Nov 1, 2006 | 06:04 PM
RKA's Avatar
RKA
AudiWorld Uber User
Did you make sure the ball joints on the end links move freely?
Old Nov 1, 2006 | 08:28 PM
B1.8T's Avatar
Default yep, reinforcement brackets are on securely
 Pouria Savadkouei
 Michael S. Palmer
Old Nov 1, 2006 | 09:14 PM
B1.8T's Avatar
Default C'MON-No One's got any ideas?????
Old Nov 2, 2006 | 04:14 AM
Not Mica's Avatar
New Member
That sounds like more of a personal problem.
