Installed new engine/transmission mounts, still have rpm dependant hum/slight vibration...
I did loosen the snub mount bracket and let it idle with the bracket loosened, however it just fell down towards the ground and was easy to move up/down, didn't seem my "aligning" was doing any good, should the bracket be tighter?
any clues? it sounds like an exhaust leak almost, but it's pretty quiet and i've had it on the lift searching for a leak that I haven't found
<img src="http://shawnkubik.home.comcast.net/snub2.jpg">
I thought it was supposed to go the other way around *shrug*
how can i even tell if it's bad or contributing to my problem?
Tightening or in my case, replacing the missing bolt, solved the issue!
Hopefully yours is equally simple and resolvable!
HTH,
