Valve Cover Gaskets 2.8L
Old Nov 2, 2006 | 08:05 AM
hanshy5's Avatar
Default Valve Cover Gaskets 2.8L
Called the auto parts place. THey have two part numbers for the valve cover gaskets. One is just the gaskets and the other comes with the spark plug boots. The price diference is ~30. Is it worth it to change or should I look for them individual of the valve cover gasket kit?
Thanks,
Old Nov 2, 2006 | 08:44 AM
Shard7's Avatar
Default Huh? Spark plug boots? As in the rubber shrouds on the ends of the ignition wires?
<center><img src="http://autohausaz.com/secure/PartImages/078198025.jpg"></center><p>
There are two actual gaskets on each bank, one goes around the perimeter of the head, the other seals around the spark plug wells. You'll want to replace both of them at the same time. The same set fits either the left or right banks and they run about $25 a set if you shop around (autohausaz.com is where I got mine).
Old Nov 2, 2006 | 02:03 PM
CK NYoC's Avatar
do you have the 12valve or 30valve?
Thugsurus
May 11, 2017 04:41 PM
Toiffel
Jan 3, 2011 04:36 PM
Barty
Nov 13, 2007 02:02 PM
chris1
Audi Original "S" Cars
13
Apr 7, 2007 06:07 PM
Big Ern
Dec 30, 2002 07:00 PM
