ABS/Brake light... Also, VAG-COM info?
Old Nov 2, 2006 | 12:16 PM
Pscheoverdrive's Avatar
Default ABS/Brake light... Also, VAG-COM info?
My ABS and Brake lights go off after a little slip and sometimes just after hitting a bump... Anything I should check for? They just blink on, then go out after. The ABS seems to work alright, though I haven't had to use it after the lights started going off.
Also, can someone fill me in on the VAG-COM deal? How much is one, where do you get it and does it work w/other cars? I have an old laptop (it has a mouseball!) that would serve the scan function nicely.
Thanks in advance!
Old Nov 2, 2006 | 12:17 PM
Casablanca Avant's Avatar
Member
Default go here
www.vag-com.com
Old Nov 2, 2006 | 12:23 PM
Ertman's Avatar
Default does it beep and flash THREE TIMES????
Three times usually = bad news, ABS module may be going bad. If it beeps once, check the brake reservior, the level sensor might be getting stuck in the down position.
Old Nov 2, 2006 | 12:25 PM
jguthrie's Avatar
Or it's a dirty or bad sensor.
Old Nov 2, 2006 | 12:37 PM
manualAvant's Avatar
Default that doesn't even look legit
<ul><li><a href="http://www.ross-tech.com">Ross-Tech VAG-COM</a></li></ul>
Old Nov 2, 2006 | 12:42 PM
Member
either link gets you to the same company
Old Nov 2, 2006 | 12:53 PM
jguthrie's Avatar
Default Looks like vag-com.com is at best a reseller trying to look like they are Ross Tech.
and at worst its a scam.
A8LDriver
13
Nov 29, 2010 04:19 PM
donromani
13
Dec 28, 2009 01:34 PM
4ever Quattro
Aug 26, 2008 06:44 AM
cloudpicker
Dec 9, 2004 07:33 PM
EhhFour
Feb 8, 2002 10:52 AM
