Oil smells bad like gas...
Old Nov 4, 2006 | 10:14 AM
A4ORCE1's Avatar
Default Oil smells bad like gas...
When I shift my car from first to second and give it gas it sputters, until I get it over 2K-2.5K RPMs. What is my issue? no CELs?
Old Nov 4, 2006 | 10:33 AM
JA4T's Avatar
Member
Start by checking your spark plugs.
Old Nov 4, 2006 | 11:13 AM
A4ORCE1's Avatar
Could that cause the gas smell in the oil?
Old Nov 4, 2006 | 01:30 PM
kenny (dremel)'s Avatar
Plugs and vacuum lines. First and cheapest place to start.
Old Nov 4, 2006 | 02:26 PM
audinutt's Avatar
25 Year Member
you need to vag it and see what is going on, boost leak? dying MAF
Old Nov 4, 2006 | 02:51 PM
RallyVermont's Avatar
Mr Mc Feely
yes if the plugs are not firing.. fuel could be blowing by
Old Nov 4, 2006 | 04:57 PM
Shep 1.8T's Avatar
Member
Default all the obvious answers first
spark plugs, etc. Also you may want to get your injectors cleaned/squared away.
Do you have a compression checker ? Test the compression, see if teh head gasket is blown in one cylinder, doubtfull, but a possibility no less.
Old Nov 6, 2006 | 10:34 AM
A400's Avatar
Default U issue if nothing else going on is Rich mix. Gas in oil means U wash down cyls.
Could be some other things, but apparently you are so rich the gas is settling into the oil on the compression or intake stroke.
Rod
 Pouria Savadkouei
 Michael S. Palmer
Old Feb 11, 2007 | 10:45 PM
herptile's Avatar
New Member
Default You ever figure this one out...I have similar symptoms
Oil stinks like gas but no CEL's
tuneda4
Feb 26, 2008 12:08 AM
PanzerWagon
Nov 1, 2006 06:45 AM
bojan
10
Mar 31, 2003 03:01 PM
maintz
Misc. Models Discussion
Oct 29, 2000 05:40 PM
