Wheels & Tires Discussion Discussion forum for all questions and topics regarding wheels and tires
Does an 18x8.5 BBS RKII with tyre weigh less than a stock S4 wheel/tyre?
Old Sep 20, 2000 | 04:24 AM
NedK's Avatar
Junior Member
Old Sep 20, 2000 | 09:48 AM
Another Drew's Avatar
Guest
Default Careful with the rim/tire combo
the rkii has an offset of 32 and if you combine them with 235's you'll definitly have to roll your fenders. BTW, i don't know if the wheel tire combo will weigh less than the stock wheel tire combo but the rkii weighs in at 24.9 lbs for the 18x8.5 while the stock avus is about 27.<p>Andrew Lee
00 S4
<a href="http://131.107.68.28/a4.org/registry/details.asp?car=1061">
<img SRC="http://pictureposter.audiworld.com/AudiWorldPics/2000/ahlsignature.jpg" BORDER=)></a>
Old Sep 20, 2000 | 05:12 PM
loanshark's Avatar
Junior Member
Default Not so...
I have 18x8.5 RXII's which also have a 32mm offset. I'm running 235/35 Pilot Sports and the car is lowered with H&R CO's (about 1.6" drop). Even with three passengers they will not rub under hard cornering. I had the front a bit lower before but it was only then that the fronts would rub the inside lip of the fender. No problems with my current set-up.
Rami<p><a href="http://photos.yahoo.com/bc/ezcl?d&.flabel=fld1&.src=ph"><img src="http://i6.yimg.com/6/8697d05d/h/5cab0642/signature.jpg">
Old Sep 21, 2000 | 05:03 AM
NedK's Avatar
Junior Member
Default Thanks, Rami...
I've been drooling over your pics and decided I have to get a set!
I was going to try the RS4 wheels, but I think they'll be a bit heavy, and probably stick out a bit too far.
Did you notice any difference in ride, steering or handling when you got yours?
Rob
Old Sep 21, 2000 | 10:46 AM
Guest
Default Good to hear.
When I autox with 235's on my RCs (35mm offset), I'll get rubbing on the black plastic fenderwell, and I've got some stiff coilovers. I figured a set of wheels with 33mm offset would rub even more.<p>Andrew Lee
00 S4
<img SRC="http://pictureposter.audiworld.com/AudiWorldPics/2000/ahlsignature2.jpg" BORDER=)></a>
Vijay
RS4 (B7 Platform) Discussion
Jul 23, 2007 05:01 PM
DeutschDriver
12
Mar 9, 2006 10:54 AM
dbex
Jan 7, 2005 01:53 PM
TheMess S4
Mar 19, 2003 06:29 AM
Nick T.
Jul 12, 1999 08:58 PM
