Wheels & Tires Discussion Discussion forum for all questions and topics regarding wheels and tires
Springs
Old Sep 21, 2000 | 05:01 PM
Q's Avatar
Q
Default Springs
My car is lowered with the Koni coil-over setup. i have 17x8 wheels with 225/45/17 SO2-pp's. my question is what spring set up do i want in terms of lbs/sq in to prevent the wheels from bottoming out on the fender. i have some rubbing going on when i turn and hit bumps at the top of the wheel well.
Old Sep 21, 2000 | 10:00 PM
CMH's Avatar
CMH
Senior Member
Default Just raise the car up a little. The coil-overs are just fine.
<p><a href="http://registry.audiworld.com/audi/registry/details.asp?car=5395"><IMG SRC="http://pictureposter.audiworld.com/audiworldpics/2000/cmhatp0016.jpg" border="0"></a>
Old Sep 22, 2000 | 04:32 AM
Q's Avatar
Q
i like where it sits...i just want it to be stiffer...
Old Sep 22, 2000 | 07:45 PM
Dead's Avatar
Elder Member
Default Have the fender lips rolled
<p>12 has been enough for me.
12valve
97/Laser Red 2.8Q/5spd.
17x8 MM11-2 Wheels
RE 730 tires
Eibach Springs
Bilstien
Oettinger
Remus
Ein-Design
EBC/Greens
312mm/A8 rotors
Old Sep 23, 2000 | 09:35 AM
bitrbo's Avatar
Junior Member
Default If you want stiffer springs, you may need to have your shocks revalved
it depends on how stiff you want to go? How low is your car right now? Measured from the ground to the top of the wheel arch. I am going to run 500/600s, Corey has 700/750s and sharon has 600/700s I think. These are for S4s, the A4 uses different rates depending on if you have the 4 or the 6 cyclinder.
Dead
Sep 22, 2000 09:26 AM
Dead
9
Sep 21, 2000 11:37 AM
Dead
Sep 19, 2000 04:08 AM
Dead
Sep 18, 2000 12:44 PM
Dead
Sep 13, 2000 07:48 PM
