90 CS Quattro--tire size ???
Thanks
I ended up having one set of wheels for winter use with 205/60/15 snow tires and one set of wheels with 205/55/16 performance tires for summer use.
Check out the tire size calculator in the link below and see what the % differences are with the different sizes. As a rule of thumb, differences either way of less than 2% is acceptable. Hope this helps!<ul><li><a href="http://www.miata.net/garage/tirecalc.html">http://www.miata.net/garage/tirecalc.html</a</li></ul>
When I had a '94 90S Quattro, I'd downsize in winter to 14" wheels for my narrow snow tires.
The diameter of the two different tire sizes should be very similar. Handling will deteriorate slightly with a narrower tire, while ride comfort will improve slightly because of the higher tire profile.
If ride is most important to you, stay with what's there. If performance counts more, you may want to change tires. Or, then again, you might want to go to even bigger wheels with wider, lower aspect tires.
DMoore
'00 S4
